Super Fast 2004 KTM 50 ProSenior Fully Modified
Home Forums For Sale For Sale Super Fast 2004 KTM 50 ProSenior Fully Modified
This topic contains 30 replies, has 0 voices, and was last updated by  David 16 years, 8 months ago.
Viewing 15 posts - 16 through 30 (of 31 total)
  • #136613
    Bill
    Ollie wrote:
    Hey Bull are you going to have a play with the 85’s internalsB)
    Yeh mate there is a few things that need rethinking cooling system will be first,have 3 to do
    Then it will be up to the Rat to tune them to the boys power needs
    #137063
    And tune we will:)
    #135813
    So Guys any takers.
    #139478
    Hang in there Mr Rat (got a hat?) I had to drop the price $500 on a beautiful ’06 with as much as you could get away with scruntineering in SE QLD, had MPE tuned suspenders, the big carby, the hardparts pipe, cleaned up in side, two clutches, three seats, braided brakes and a few billet bits, all because the dealers are selling the older model for next to nothing ATM apparently.
    You’ll move it, it’s a ripper can only imagine the acceleration it has.
    #139511
    Thanks for the encouragement Mr Blue, but I will be sad to see it go:( :(
    #139910
    Bill
    Did Aarochild get the STD one from you if so i will sell him a cooling kit at a good price :)
    #140332
    So whats a cooling system kit contain and why does a KTM need one Bull, I ask because I have another one coming soon
    Bill
    Modified cyl head ,lower silcone rad hose
    For a serious racer ill also mod the water pump
    I picked the KTM 50 because my boy had one and the Rats and was watching them at a race and i commented to the Rat that the engines were going off the power after 10min and the last 5min sounded diferent and were not throwing as much roost
    The Rat came back with some KTM propaganda about the slipper clutch generating too much heat and causing the whole motor to over heat (the sad part KTM still think this is the problem)I said what a load of crap and did some testing and found a very sad cooling system no water is pumped after 7000 rpm aprox so made some proto types and got the Rats boys and mine to test it for some seasons
    Note have tested a few bikes and all have similar issues and thinking of it so do all the cars i’ve tested
    I now have some nice parts made and have it all sorted
    things the Rat and myself have noticed since the mod
    wont over heat with continual use tank after tank
    Piston rings dont wear out
    the stator doesn’t fail due to the engine cases not heat distorting
    no power fade
    #140335
    TB are you sure you really want to know, I have seen you before have dramas with concepts that dont fit the normal way of thinking, I was there myself a few years ago, and thanks to Bulls perseverance I now have bikes that dont require the service intervals, and I also have bikes that are crisper than any out there, I am also obsessed with tunes on 2strokers and this coupled with Bulls obsession with the cooling system deficiencies made a perfect partnership my boys have reaped results from…..
    Thanks Bull:) and I cant wait to get the next Moto-Cool Treatment/Development/Fitting done again
    #140339
    TB are you sure you really want to know, I have seen you before have dramas with concepts that dont fit the normal way of thinking, Thats not right and it makes sense now bull has explained above, expect one thing Bull which I will ask later I was there myself a few years ago, and thanks to Bulls perseverance I now have bikes that dont require the service intervals, and I also have bikes that are crisper than any out there, I am also obsessed with tunes on 2strokers and this coupled with Bulls obsession with the cooling system deficiencies made a perfect partnership my boys have reaped results from…..
    #140338
    KTM Bull wrote:
    Modified cyl head ,lower silcone rad hose[color=][/color]
    For a serious racer ill also mod the water pump[color=][/color][color=][/color]
    I picked the KTM 50 because my boy had one and the Rats and was watching them at a race and i commented to the Rat that the engines were going off the power after 10min and the last 5min sounded diferent and were not throwing as much roost Yes very true, I have seen dyno reports for 250 and 450 four strokes and it is amazing how much power they lose
    [color=][/color]
    No water is pumped after 7000 rpm aprox so made some proto types Most engines will drop pump volumes to unacceptable rates much lower than that we see this at work in a our dyno testing
    wont over heat with continual use tank after tank That makes sense
    Piston rings dont wear out I have a problem with that to a point, as running an engine to cool and lower then its designed running temperature increases wear rates by over 25%, 90% of engine wear is when an engine is cold remember
    the stator doesn’t fail due to the engine cases not heat distorting that would help yeah especially on those little katos
    no power fade and again would help that no end
    [color=][/color]
    My thoughts Bull, good job
    Bill
    no power fade and again would help that no end[/quote][color=][/color]
    TB[/quote]
    The ring wear is due to heat distorion of the piston barrell this is severe when there is no coolant flow and steam pockets appear in the high spots
    Cold running wear is an issue, one I have to remind the Rat of reguarly and am astounded at the no of bikes that go out cold started at the 30 sec board then have the shit reved out of them till the gate drops
    #140373
    Not anymore Bull, I have not been guilty of that for a year or so my man.
    #135814
    mate remember Lolly has first shot once she steps up from the Pro Junior i just bought off you…but not counting on it being around for that long.
    craigo
    #140442
    No worries Craigo, if it is still for sale the thing has Lolly written all over it, you tell her its hers
