Home › Forums › Product Reviews › Product Reviews › Sutto`s Grip Heaters
This topic contains 52 replies, has 0 voices, and was last updated by tracy 16 years, 7 months ago.
July 8, 2009 at 12:52 pm #142563
Finaly got the heaters on and working a charm. Only question is; because the resistor gets hot is it safe where i’ve mounted it ??
July 9, 2009 at 5:32 am #142770Think i answered my own question. If theres doubt, its wrong. So I made up a bracket and it now sits between the forks under the headlight assembly.
July 9, 2009 at 10:26 am #142796just keep it away from that giant molotov cocktail of a tank that you have JAK:laugh: :laugh: :laugh:
i havent fitted mine yet, been too busy.
i did however, use my suttos voucher to get them and i tossed in some extra coin and got some FORCE radiator guards….for only $120 delivered….the special old bulls price!!!!
they have $175 bucks on the packet….bargain!!!!!!!
thanks Mal, and all of the suttos crew, and especially TB and all at OBT for my voucher:)
i love this place!!!!
July 9, 2009 at 10:55 am #142872Yeh its well away from the tank.
Rode the bike down to the car wash about an hour ago and the heaters work well. As said earlier high is probably too high as even in this cold it started getting a bit warm.
July 17, 2009 at 7:09 am #142263Added this Water Proof Fuse Holder inline near the battery on the KLX to run the Grip Heaters,,,
Currently has a 10amp fuse,,, Is this big enough ??? Or shpuld I run a 20amp??? :unsure:
It runs fine, the heaters are awsome on the Low setting, may run on HIGH at Nundle next sat mornin` though :laugh:
Any Thoughts,,,
July 17, 2009 at 7:15 am #144173Do you have a multimeter Beagle, if not try a 10, if it blows fit a 15 amp
If you have a multimeter send me a PM
July 17, 2009 at 9:05 am #144174
AnonymousBugger – should I have put a fuse in-line?
I was so happy with the professional wiring job that I done and mounting the resistor but I didn’t fuse them.
How long does it usally take to get them hot?
July 17, 2009 at 9:07 am #142264Mate, about 3 mins and ya can feel mine , even on the left grip that aint insulated at the bars!!!
High is too hot for me;)
I ran em on LOW to work this week & its GROUSE:woohoo:
July 17, 2009 at 9:11 am #144194
AnonymousThats good obviuosly I got everything right cause I can feel ours in about the same time. Did you wire yours off the battery or the light circuit? I done ours off the low beam wire on the headlight.
July 17, 2009 at 9:15 am #142265Ummed & arred for a few days,,, then wired direct from the Battery (with the heavy duty stainless switch with rubber boot (from Bias Boating)
July 17, 2009 at 9:24 am #144196DanD wrote:
Quote:Thats good obviuosly I got everything right cause I can feel ours in about the same time. Did you wire yours off the battery or the light circuit? I done ours off the low beam wire on the headlight.You should be fine with the wiring anyway,,,,
I did mine from the battery purely as I am commuting a lot & didn`t want the risk of the wire shorting out & losing the headlight whilst on the Blacktop:blink: Its DARK every mornin` & most arvos for me,,,Thats the main reason for the direct battery hook up!!!
Plus the KLX is a wiring rats nest behind the headlight:huh: :dry: :unsure: :blink:
Simple route for me to the black box,,,July 17, 2009 at 9:30 am #144198Heated grips on hard core dirt bikes :blink: maybe riding to work, dual sporters and road bikes
You guys should get some new riding gear as well
July 17, 2009 at 9:31 am #142458
Anonymouschampo35 wrote:
Quote:now it seems fine. and yamaha australia now boasts that the new models have a new upgraed charging system. for extra fun!!! extra fun because the bike starts again after 40mins now.I remember that problem well – Kylie’s TTR230 had the same problem – funny how a Yamaha f**k up has became a feature now.
But to give Yamaha credit they did fix Kylie’s even though it was out of warranty.
July 17, 2009 at 9:34 am #144199Trailboss wrote:
Quote:Heated grips on hard core dirt bikes :blink: maybe riding to work, dual sporters and road bikesYou guys should get some new riding gear as well
Hey TB,
Puddles just PM’d me and asked if you could make sure you keep one in his size, he loves it:laugh: :laugh:July 17, 2009 at 9:36 am #144200
What then we will match you TB:P
