sw motech centre stand for Tenere
Home Forums Tech Help Tech Help sw motech centre stand for Tenere
This topic contains 5 replies, has 0 voices, and was last updated by  Greg 12 years, 9 months ago.
  • #102871
    Bits that I’ve ordered for my new Tenere have started arriving :)
    Last night I fitted the SW Motech centre stand I ordered from “Off the Road”
    It went on fine, but I’ve noticed it doesn’t have a rubber grommet to stop it hitting the rear linkage.
    Is this normal ? Or is it missing a part ?
    Other thing I’ve found is that the new chain has stretched ( a lot ) & is rubbing on the centrestand. Quick adjustment tonight will sort that !
    Any help most appreciated.
    Bucky
    #243626
    Bucky
    Ummm not sure about the grommet Bucky a picture would help.
    Yes the chain appears to hit when sitting there without the rider on board (when correctly adjusted) but doesnt when you are on it.
    Unless your 60kilos and dont plan on putting luggage on board get your suspension done, makes the biggest difference and helps with the chain on the centre stand
    Welcome to the white club BTW
    John
    Bucky,
    Had a look at mine, don’t know the stand brand but here’s some comparo photo’s.
    Yes the bike is dirty, I ride it. Polishing is for HD riders… ;)
    The rubber grommet is in the top left touching the swing arm when the stand is up. Chain doesn’t touch anywhere.
    Another view
    Centre stand up
    Rubber grommet when stand down
    #243628
    Thanks TB
    With the centrestand – every other bike I’ve had has had a rubber stopper on the centrestand to hold it off the chassis / stop it banging when you hit bumps etc. The SW Motech didn’t come with one.
    Will look into the suspension when finances permit !
    PS – Glad I got picked white. Not many around & they look the business !
    #243631
    Cheers jtb,
    Your centre stand completely different design to SW Motech one I’ve fitted.
    Thanks anyway,
    #243632
    Yeah his is different to mine. I will take some photos of mine on the weekend and if you can get a few photos of yours up it would be good
