T6 Filters
This topic contains 20 replies, has 0 voices, and was last updated by  Greg 17 years, 2 months ago.
  • #117213
    10″ metal steel ball is bigger than the 100mm piston in the fiddy your right! Fark what pressure is working against that valve?
    60 bar.g or 882 psi :)
    #117219
    Nah same same, as XR 650 with HRC kit! :woohoo:
    Will have to sit down one day Moto and learn a little about the boiler systems you work with, would like that
    The fiddy piston wouldn’t come close. The new Maico however….:silly:
    #117222
    Same same, check spec’s 100mm , the Maico is only 658cc or something spec
    #117223
    I was playing, I knew from the Maico thread that they have exaggerated the fact it’s a 700 when it’s much closer to a 650. Still sounds good though, and a 2 smoke :ohmy:
    #117238
    Yeah sounds like OMG! WTF!:woohoo:
