TB’s New Tenere #5
Home Forums Yamaha Bikes Yamaha Bikes TB’s New Tenere #5
This topic contains 2 replies, has 0 voices, and was last updated by  Greg 10 years, 8 months ago.
  • #104271
    Sold my old Tenere, a guy wanted it. So the build has commenced in earnest on my new one. I have stripped the new bike. Drilled the ignition barrel mount ready for the steering damper, mounted the USB charger in the dash, got the forks and hub ready for Nick at Teknik’s to mod the hub. My Ohlin’s shock will be serviced as well. I sold my last one almost complete as I kept my shock and ordered a Yacugar shock for the old one, when I say complete I mean bags, GPS the whole shooting match. I am waiting on parts from everywhere at the minute as it all happened so quick really as I only wanted to sell it stock.
    Making some changes to the forks after some development with Nick, trying a few different setup changes after some feedback recently. Will post up some more photos as it goes along
    Wiring for the 2 3BR USB plugs, the 2 GPS power supplies, the LED driving lights and the spare back up power supply.
    LED blinker installed as they are smaller and brighter. They are a Yamaha kit basically plug and play
    Old grip around the water pump hose for extra protection
    Another look at the hose and the new B&B bash plate
    Cush hub modified by Tekniks at Penrith. The hub is machined and a Chinese twin row bearing is installed. The Chinese bearing is $15 and the last one is still going at 33,000kms. Normal cush hub bearing replacement for me was 10 to 15 thousand. For those that don’t know the standard bearing isn’t directly in line with the sprocket thus the standard bearing is always being side loaded. The twin row bearing lines up under the sprocket.
    New Pro Windham Mid Bend bars, high screen, barkbusters, grips and GPS mount
    Head light protector
    This is the 3rd B&B radiator guard I have fitted and as with the previous ones the guard need modification before final installation or damage could result during a simple crash. The problem is the lower triple clamp hits the radiator guard instead of the stop.
    You need to remove the steel inserts from the rubber radiator mounts because when the old guard is removed the inserts when reinstalled prevent the rubber mounts from having any crush thus allowing the radiator to flog around. Once the insert is removed file/grind about 4mm from the sleeve so the head can allow some crush on the rubber radiator mounts
    Once modified the triple clamp has clearance both sides as seem below
    Ohlins shock installed after being serviced
    Adventure Moto multipurpose racks fitted
    More later
    Steve
    Was going to give you a few tips,but looks like you have it under control.
    #260490
    Well it has been a fav number 5. Never actually crashed this one ;) not like the previous one :ohmy: :whistle: Only dropped it twice in the 13,450kms its done in the 7 months I have it.
    New one ordered, new color scheme as well :woohoo: :woohoo: :woohoo:
    First ride, left for 5 days in the high country with 4kms on it !!
    See you later ol mate
