Tenere filter skin modification !
This topic contains 3 replies, has 0 voices, and was last updated by  Nick Jackson 14 years, 5 months ago.
  • #100638
    Filter skin mod
    Clean bike 1st :whistle: :laugh: :laugh: :blush:
    Remove existing filter cover bolts and disregard.
    Remove standard filter cover.
    Cut 4 pieces of threaded rod about 35-40mm long.
    Loctite studs into airbox in place of cover bolts.
    Fit DNA filter cover over the studs and secure with nuts.
    Buy a pool filter sock ( $6 for 5 from Coles).
     Oil filter sock
    Take standard filter cover
    Fit filter sock over filter cover
    Install over studs and make small cut in filter sock to allow it over the studs
    Secure in place with nyloc nuts
    Now it’s easy to replace the filter sock daily on a dusty ride without disturbing your foam filter.
    #210993
    Good job Nick mine is now the same. I love the DIYs helps one and all thanks for making effort ;)
    How ever did you think off such an idea 😆
    Fantistic work Nickj!
    I will do the same as soon as my DNA stuff arrive in the mail. :cheer:
    Cheers, TT
    #211031
    Cheers, TT
    The good thing is TT if your on a solo or dust free ride it’s really easy to run without the filter skin and small enough to stash somewhere just in case :)
    I carried 5 Pre-oiled skins in a zip loc bag cable tyed under the seat and only ended up using 2 of them. When I got home and checked the inner of the unifilter it was virtually clean ;)
