Tenere front brake lines
Home Forums Tech Help Tech Help Tenere front brake lines
This topic contains 3 replies, has 0 voices, and was last updated by  Sean Ramsay 9 years, 1 month ago.
  • #104767
    Sean Ramsay
    Hey guys been awhile,
    I noticed my front brake lines are leaking, anyone else replace these with braided line? If so did you go for the “banjo bolt” option?
    Thanks guys
    Sean
    #263674
    Hey Bender,
    Try looking through these:
    http://www.obtrailriders.com/index.php/forum?view=topic&catid=18&id=91879
    http://www.obtrailriders.com/index.php/forum?view=topic&catid=18&id=103115
    If you dont have any luck maybe send TB a pm?
    Happy reading!!
    #263675
    Not on a tenere but I have had braided lines on other bikes and they do give better feel. Not sure what you are asking about banjo bolts though, they should just fit up with the original bolts. Maybe replace the washers though.
    #263676
    Sean Ramsay
    I probably didn’t describe what I meant about the banjos, the tenere as you probably know has the one line that comes of the master cylinder and then splits into two lines behind the forks, the only real option I could find was a system that uses a double banjo so both lines come straight of the master cylinder, I’ve since ordered and will let you know how it goes if anyone is interested lol,
    I re-read TB’s old posts Trailerider and didn’t see any mention of touching the brake lines, probably the only bit he didn’t tweek lol
    Cheers guys
