Testing a Coil
Home Forums Tech Help Tech Help Testing a Coil
This topic contains 3 replies, has 0 voices, and was last updated by  corey heather 14 years, 5 months ago.
  • #100577
    John
    I’ve got a few quad bikes, but i cannot remember the brand name of this one. :blush:
    Anyway I cant get a spark. The bike ran fine one day then the next wouldnt start. The spark was weak, then a couple of days later I couldnt get spark at all.
    How do i test the coil and/or should i be looking elsewhere ?
    #210185
    Your probably best to disconnect all kill switches completely before going any further – if not done so already.
    #210186
    Hey Jak, with a test light test for pulse to the coil when the quad is cranking by connecting to earth and probing the power wire or if it has 2 terminals like a car coil just across the coil. The light should flicker if the trigger is working.
    If you are getting trigger signal to the coil and it is not producing a spark it is either the lead(high resistance) or coil.
    Steve
    #210200
    Same thing happened on my son’s chinese quad and it was the plug that had shit it self
