There has to be another option ……………….Surely
Home Forums Kids / Fun / Pit Bikes Kids / Fun / Pit Bikes There has to be another option ……………….Surely
This topic contains 33 replies, has 0 voices, and was last updated by  alan 13 years, 2 months ago.
Viewing 15 posts - 16 through 30 (of 34 total)
  • #231941
    GoKTM…… TB likes em… :laugh:
    #231980
    swallow your pride Bob.
    dont let your son suffer for your racial prejudices :laugh: :laugh:
    he deserves better, he deserves a Kato!!!!
    #231989
    Matt
    I think Suzuki JR80. I saw one going around at the taree track a couple of months ago looked good. Oil injected low maintenance.
    http://www.suzukimotorcycles.com.au/bikes/off-road/two-wheel-fun/2006/jr80.html
    44
    #231992
    I went through the whole 50cc scenario with my daughter.
    We started her on a PW50 then we got a KTM mini adventure, then she progressed to the KTM pro senior of which we had two. She raced all four bikes and she was fastest on the mini adventure I think. Being air cooled and not so highly strung it was easier for her to manage. And it just kept going and going with minimal problems. The Pro senior however, was a totally different kettle of fish, it was loud and obnoxious and toey as a tom cat. If you let her ride it for to long on a grass track the things would get hot and burn the stator out and it would run like a hairy goat until you forked out the $160 for a new stator.
    Once she started to get to tall for the pro senior and it was time to learn how to change gears we got her a PW80, once she got the hang of that and it was time to learn the clutch, she spent some time on a DS80 (JR80). once the clutch and gears were mastered we put her on a KX65 and she never looked back, the KX’s are great little bikes, we have had 4 over the years with out an issue of any sort and now she has a KX100 that goes like a scalded cat.
    If your young bloke is small in stature at the moment, I would seriously look at a KTM mini or senior Adventure.
    #232001
    Bob Dowsett
    Is the pro senior the same as a sx50
    50sx mini
    50 sx mini adven
    sx50 ?SEnior junior??
    WTF :)
    #232002
    The SX and the Pro Senior are the one and same. After 09 they started calling them Mini SX (I think)
    I think they make a Pro Junior as well, Both are water cooled screamers. :pinch:
    The Adventure series comes in both Senior and junior versions. The Junior being shorter in seat height.
    The Adventure series are more user friendly, being air cooled and a whole heap quieter!
    #232005
    Just google the KTM website you stupid farmer :laugh:
    50 sx = too tall
    [attachment=3621]2012Ktm50sx.jpg[/attachment]
    50 sx mini = just right
    [attachment=3620]50_SX_Mini_2012.jpg[/attachment]
    #232003
    gas gas electric ;)
    2013 SX 50 mini :
    Engine Type1-cylinder 2-stroke engine, water cooled, with reed intake
    Displacement 49.0cm³
    Bore / Stroke39.5/40mm
    Starter / BatteryKickstarter
    Transmission Rigid 1-stage reduction gear
    Fuel Management Dell’Orto PHVA 12 XS
    Lubrication Separate lubrication
    Primary Ratio33:61 straight cut spur gear
    Final Drive 10:42
    Cooling Liquid cooling system
    Clutch 3-lining automatic clutch on the main shaft / centrifugal force
    Ignition Selettra 2p D36
    Frame Central tube frame of chrome molybdenum steel tubing, powder coated
    Sub-Frame steel
    Handlebar aluminium tapered
    Front SuspensionWP Suspension USD 35
    Rear Suspension WP Suspension 3614 BAEM
    Suspension Travel – Front / Rear100/171mm
    Front / Rear BrakesDisc brake 160mm front / 140mm rear
    Front / Rear Rims1.6 x 10″ / 1.6 x 10″ aluminium
    Front / Rear Tyres2.50 x 10″ / 2.75 x 10″
    Chain 1/2 x 3/16″
    Silencer aluminium
    Steering Head Angle67.4º
    Wheel Base914 ± 10mm
    Ground Clearance184mm
    Seat Height 558mm
    Tank Capacity approx.2.0l
    Weight Without Fuel approx. 40.5kg
    _______________
    2013 SX 50 :
    Displacement49.0cm³
    Bore / Stroke3
    TransmissionRigid 1-stage reduction gear
    Fuel ManagementDell’Orto PHBG 19 BS
    LubricationMixture oil lubrication
    Final Drive11:40
    CoolingLiquid cooling system
    Clutch3-lining automatic clutch on the main shaft / centrifugal force
    IgnitionSelettra 2p D36
    FrameCentral tube frame of chrome molybdenum steel tubing, powder coated
    Sub-Frame steel
    Handlebaraluminium tapered
    Rear SuspensionWP Suspension 3614 BAEM
    Suspension Travel – Front / Rear200/185mm
    Front / Rear Rims1.6 x 12″ / 1.6 x 10″ aluminium
    Front / Rear Tyres60/100-12″ / 2.75 x 10
    Chain1/2 x 3/16″
    Silencer aluminium
    Steering Head Angle 66º
    Wheel Base1032 ± 10mm
    Ground Clearance 252mm
    Seat Height 684mm
    Tank Capacity approx.2.3l
    Weight Without Fuel approx. 41.5kg
    __________
    all specs taken from http://www.ktm.com.au/Minicycle
    basically the new SX 50 Mini and SX looks like wheel size, seat height and suspension travel.
    as for older models if you are looking for second hand, i have no idea. but what’s new there.
    #231942
    Bob Dowsett
    I’m not fu234king stupid :ohmy: all the time , I can use google
    all that crap doesn’t tell me what you can and can’t modify to you own requirements :laugh:
    I’m of the suspicion a mini of any version may only suit him for 6 months
    #232006
    Bob Dowsett
    at least I’ll be able to hear and find him when he’s at home :laugh:
    #232022
    I’m of a suspicion that the 50 sx might be too tall for you also :laugh:
    Looks like they don’t make the senior/junior/adventure anymore.
    #232024
    Crf 70
    There not to big and he will have it for years. My daughter has one and the young fella has a jianshe py 80. He will get the 70 when she hates bikes.
    #231943
    Bob Dowsett
    apparently???? the adventure models stopped in 07????
    I’m about sick of this shite 👿
    Maybe he can walk
    #232025
    ian
    i think thats the main issue with any kids bob they grow out of them quick im lucky theres 20 months between my 2 boys im gettin roughly 2 years out of each bike as they get handed down by the time i get the second year my youngest has well and truly grown to move on.
    The ktm sx junior i have at its highest seat height is 600 mm and with the lowest its about570mm (this is with the lower seat that i have) ive seen other ktms have the stator problem but they also have the clutches set up so they are either a light switch on or off with there power so to get them going there working hard all the time but thats only the way you set the clutch up you can have these bikes a little bit tamer with a bit of mucking around.
    I thought about going the crf 70 way but its also 20 kg heavier seat is 663mm tall and at that stage ( my boys were 6&8 and also short asses) didnt think it was the way to go
    i feel for you mate its a hard to say which way you should go take him in to the honda dealer and see if he could go a crf70.
    what ever bike you buy it wont last that long before they grow out of it but the key is ( i think anyway ) dont but to much bike so they keep on falling off and dont want to get back on it
    #232035
    ian
    to give you an idea on size heres when i first bought up against a kdx 50 at its lowest height with the low seat on
    and heres one 12 mths later next to the ktm 65 before i got the 65 lowered and the 50 was at its tallest height
