Theres some in this,,I think
Home Forums General Bike Talk Theres some in this,,I think
This topic contains 19 replies, has 0 voices, and was last updated by  Craig Hatton 15 years, 11 months ago.
Viewing 15 posts - 1 through 15 (of 20 total)
  • #98308
    My ride report for yesterday.
    Starts off fridy arvo, knocks off work hits home grabs a stubby, kiss the missus and I`m off to the shed to put the 400 back together for some roostong on sunday.
    Start the task with fitting the new kenda carlsbad to the rear, gets it half on and sweat is pooring out of me and then I hit the wall. Back at the house throwing up me ring,fair dinkum I havent eaten corn in months , but sure enough some came up, Gets packed off to the sack apparently looking like a rolf harris painting.
    gets up saty and feeling ok, off to the shed I heads, finished putting the tyre on and pumps er up and pops the bead, sweet, put it on the bike and starts to put all the plastics back on after a good clean.
    40 minutes later I fires the old girl up thinking ,go dig the lawn up with the new kenda, looks to admire me handy work and root me boot shes flat as a tack.
    off the wheel comes and I discover I pinched the tube ,so I patch it and pump it back up,,alls good.
    a couple of furrows in the lawn later I put the bike back in the shed,only to discover the ruddy tyre was going flat,off it copmes again and the patch replaced, on the tyre goes and I break out the compressor and the tyre doesnt inflate, crickey am happy by now, off comes the tyre again and I discover I pinched the bloody tude again,this happened once more and then I decided that Bollocks WR250 sitting in my shed needed a riding, I rings Bolls to confirm its ok to borrow the beast only to get his answering machine.
    I tells the bride of the great time I`ve had and she says that something is telling me not to go riding the next day.
    I didnt take any bike riding on sunday and i recon somehow some where I have dodged a bullet???
    #175819
    curses, foiled again :laugh: :laugh:
    i had it all set up to pounce boony, ;)
    set up the kanga traps
    starved all the bunyips
    had some big rutts dug in precarious places
    got some gates installed
    back up bike organised
    oh, well :P
    at least you got the food poisoning bit :laugh: :laugh: :laugh:
    back to the drawingboard :woohoo:
    #175826
    See thats why I like you……your different,very,very different.rsole :laugh:
    #175829
    ian
    ah yes!! nothing better than wrestling around with a tyre i have had those things happen as you run out of time and patches and cans of bourban for that matter before sunday morning ride start time, but the more you do it the better you get at it , thats the only sort of support i can give you Boony
    #175836
    if you can fit a kenda carlsbad boony any other tyre will be easy those pirrelis are real easy as are bridgstones
    #175842
    and Michelin’s ;)
    I can change a kenda as quick as it takes menace to have a naughty,,actually I`m not that quick :laugh: :laugh: :laugh: :laugh:
    #175844
    seriously rocket keep the oppersite side bead down and use good levers (pro motion) and they really arnt that bad.start at the oppersite side to the bead lock and bobs ya uncle :)
    #175846
    YOU PINCHED THE TUBE 3 TIMES BOONY YOU CANT CHANGE A KENDA OR ANY TYRE FOR THAT MATTER BASED ON THAT
    :laugh: :laugh: :laugh: :laugh: :laugh:
    Ollie is better then that and thats a shameful fact for you Boony :P And Ollie was the worst I ever saw or heard off :laugh: :laugh:
    they can not be that good if you keep pinching the tube .used to use them kendas all the time but the cheap supply dryed up there a good tyre but hard sidewall don t get many flats or dinted rims .grip good round dubbo last okay to just my apionion
    #175848
    now you see the meat of this thread, normally I can throw them on pretty quick, this weekend was weird,
    But I am not saying I am good at it . :huh:
    #175852
    white rocket wrote:
    they can not be that good if you keep pinching the tube .I trashed my rims using them stuppid pointy ended levers, not worth a pinch of dog poo in my books.used to use them kendas all the time but the cheap supply dryed up there a good tyre but hard sidewall don t get many flats or dinted rims .grip good round dubbo last okay to just my apionion
    #175849
    When have you seen me change a tyre chocolate Lips :dry: Only conjecture and misrepresentation around the circle of Knowledge :( Yep I do need some practice,given but changing tyres shits me :laugh: I must admit boony those Kenda’s are a bitch to fit they are so much tighter than anything else I have ever done,except maybe a Trelleborg (remember those?)
    I have watched you change a tyre ollie, and in your defence it was a mistake anyone could make :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: I still get a giggle out of that, It is something that would only happen when everyone is looking.
    #175856
    Reckon you dodged a bullet there Boony mate. Karma was out for you and when that’s the case you’re best off limiting the weapons it can use against you! Dirt bikes give Karma too much ammo!! :P
