thermo fans on crf250x
This topic contains 5 replies, has 0 voices, and was last updated by  Greg 15 years, 7 months ago.
  • #98831
    scott hurley
    apart fron the cooling factor is it worth fitting thermo fans?
    also thinking of changeing the display how hard is it to do want one that is electonic and temp guages on it ect
    #185642
    Aaron Wilde
    Have heard about people putting them on commodore 450’s to stop them boiling at the lights. You would want to be all the time riding some pretty technical slow lots of clutch crap to need it i reckon.
    #185645
    Try a VAPOR TRAIL TECH SPEEDO/TACHO mate some kit numbers here
    You see them on E Bay sometimes.
    Thermo fan would be good if you do a lot of real slow going, stop start etc. They can be purchased in kit form although some guys use ball bearing computer fans with an on / off switch on the bars
    Scotty
    Fitted a Trailtech Vapor to an 06 crf250x no problems. I picked up the tacho and power off the original speedo (crack in the original speedo caused the display to go black). Fitted the speedo pickup as per the instructions and fitted the temperature sensor as per the instructions. All works well. If you decide to go that way I can give you the colours for the power and tacho if you need.
    With the Vapor speedo you could then see what your maximum temperature gets to and decide if you have issues with getting too hot (your bike at least anyway).
    #185644
    scott hurley
    thanks tb vapor kit 75401 ordered and on the way will try this update with temp readings to see if thermos even needed
    cheers scotty :cheer: 😆 😆
    #185728
    No worries Scotty happy I could help. Mal5.1 has one and likes it and I am now thinking about one for the XR but wasnt impressed years ago with their cheaper cousin but it all seems better now
    Cheers again mate
