Tie down brackets
Home Forums Product Reviews Product Reviews Tie down brackets
This topic contains 39 replies, has 0 voices, and was last updated by  Dean 17 years, 4 months ago.
Viewing 15 posts - 1 through 15 (of 40 total)
  • #95372
    I was supplied these stainless steel bracket from the workshops of one of Australia’s defence forces. I won’t say which one, but it has something to do with boats B)
    The brackets came undrilled, but were supplied with fitting instructions as to hole size and spacing. As they are constructed from 3mm (maybe a bit thicker) s/s plate, there was no need for longer fork clamp bolts. The existing bolts still had plenty of threads inserted into the triple clamp casting. Installation was a breeze. Even the mechanically inept Moto could probably even master it.
    The pricipal behind this style of tie down point is that by lowering the point at which the straps attach to the bike, it increase the angle of attatchment. This more obtuse angle provides more stability, and less chance for the bike to sway sideways. The issues of the bars being damaged by chaffing of the tie-down hooks is also eliminated.
    Having said all that, I haven’t actually tried mine in the real world yet. They could actually be a load of crap and end up failing and flipping my bike off the trailer and hitting a crowd of disabled nuns on the footpath 😆
    Here are some pics for your perusal.
    #112130
    Good for those like me who don’t want scratches all over the bars from the Tie Downs.
    #112136
    Not a bad idea,they sell a similar thing on ebay always thought just another edge for me to get ripped on or to create an intrusion into my person, but then i am prone to injury so i use soft straps on my tie downs.
    good if you can get them for Nix.
    Blue
    #112138
    Blue
    I am not sure what brand/model of bike the “Nix” is, but I am sure you could get some for it, or at least modify another brand’s brackets :)
    #112139
    slug wrote:
    Blue
    ha ha ha You certainly look at things outside the square don’t you Nigel?
    #112140
    Nah! I just have an over-active, immature childish mind, pumped full of medications.
    #112141
    shane
    My tie-downs have a loop on the end that attaches to the hook. could loop that soft end around the fork leg up near that triple clap, save attaching the new thingo. Good idea if one doesn’t possess soft tie-downs though.
    Now, get back out into the shed and make up some of those rear wheel tie downs out of steel cable…
    #112143
    GUYS I ACTUALLY MAKE A SELL THE SOFT TIE DOWN LOOPS FOR THE TIE-DOWNS THAT DONT HAVE LOOPS . OR IF YOU WANT TO GET THE HOOKS EVEN FURTHER AWAY FROM YOUR BABY, AND I ALSO PUT THEM DOWN LOW FOR ALL THE SCIENTIFLOGICAL REASONS MENTIONED BY SLUG.
    HERE IS A PICTURE AND ANOTHER TO SHOW THE COLOURS
    [img=http://xs433.xs.to/xs433/08464/soft-straps-new-1179.jpg]
    #112145
    Dave is it you that also makes them embroided lift straps I see on a heap of bikes at the track?
    #112146
    Yes Mate, I sure do.
    I am leaving to go to you joint now
    #112148
    See ya there,I will piss off early from work then!
    #112149
    Dont rush I have to go to town first
    #112147
    Like this sorta thing? http://www.thetugger.com/
    Maybe there is an opportunity to offer some product as prizes for the Old Bulls xmas party , particularly a lift strap for an 04 wr450f :dry:
    #112144
    post deleted by me.
    #112155
    Slug those Tugger guys actually copied my thing from 6 years ago.
