Tie Wire (lockwire) Size Question.
Home Forums Tech Help Tech Help Tie Wire (lockwire) Size Question.
This topic contains 16 replies, has 0 voices, and was last updated by  Anonymous 17 years ago.
  • #95897
    What size wire do those tie wire pliers use? As much as I love tools, I can’t justify buying a set, but was curious if they just use the same tie wire that I have seen in rolls at Bunnings.
    Leading on from that, if you do use the Bunnings type wire for handgrips etc, what size of that do you use. Please be specific, not just “the small guage stuff” type answer. I have read that some riders use Mig wire, but I don’t have access to that sort of stuff.
    I just use copper wire to “lockwire” the sump plugs and oil filter bolts, but will soon need to replace the hand grips and the copper wire just won’t tighten up enough without breaking. Maybe I should just glue the grips on.
    Slug
    #123049
    Slug, I believe the tie wire is Stainless wire, the stuff at bunnings is gal or similiar, have tried it bit won’t tighten enough before breaking just like the copper.
    #123050
    Nick Again
    mate I cant offer much help on the wire sizes but I’m pretty sure I’ve seen the pliers/wire in a kit thats rather cheap.under $30.00? once you got them, you always got them? :( Sorry not much help i guess?
    #123052
    Being the unemployed scrounger that I am, I twist the wire using a hand drill and a wire hook mounted in the chuck. I loop the wire over the hook, wind the crank hand. It may be a crude method, but it works like a champo!
    #123053
    I lock tie everything on the race bikes and I only use the proper .032″ Safety tie wire, Mig wire is to brittle and you cannot get the tension right without it breaking, the tie wire pliers are worth their weight in gold if you are planning to use them on more than one bike and we race four so it was worth it to me, you can get real cheapies from ebay.:) Try this http://www.parrmotorsports.com thats what is written on the roll I have
    #123055
    Same as rat on all accounts, my bike has everything bar the rider lock wired on it and it should him wired as well :laugh:
    #123057
    Yeah I tried that TB but they thought I was a bit extreme at the races, so now we just use speed tape on the hands…..they were right the tie wire could cut into them I suppose:huh:
    #123058
    or if you want the good stuff try this
    Ebay Item number: 230324085141
    #123061
    I think Ollie The Importer may also have these pliers on his inventory and can offer them at a FANTASTICALLY cheap rate to fellow members, especially the tight arsed ones. :)
    Ollie??????
    #123056
    Just saw that mob (www.parrmotorsports.com) on ebay. About $40 delivered for a 1 lb roll. approx 347 feet.
    #123063
    I got a set of cheap pliers off ebay years ago and the cutting part screwed up in the first six months, but the swivel and clamping parts still work fine, and for the $20 I paid years ago its good value, I just use side cutters to cut the wire now and its all good, I think I have about 50 years left in the pliers yet:laugh: :laugh:
    #123062
    Ollie??????
    F#@%k Off!!
    seriously though, I imported very high quality ones from the states and they will last a lifetime but because our dollar is crap I dont have any in stock and probably wont in the near future. like Dave mentioned .032 annealed stainless steel wire the grade to use is 304
    the cheap ones are perfectly ok to use
    #123068
    I don’t use lockwire, so things come loose, but not my handgrips. I put insulation tape on the end of the bars, swish some petrol inside the grips and bung them on. The petrol melts the grips and they cure on to the insulation tape and NEVER move! Top tip!
    #123054
    Nick Again
    I like the sound of this very much, Especially since i own said hand drill and not the wire twisting pliers….thanks for the tip slug…i shall investigate this method..Though I’ve NEVER had grips come loose or off the bike.
    #123071
    Wireing your grips is only used to stop water and Mud from working its way up the tube.you should also use glue/petrol or whatever to work in conjunction with the wire. Happy Days
