Timing Chain How Much Damage??
Home Forums Tech Help Tech Help Timing Chain How Much Damage??
This topic contains 7 replies, has 0 voices, and was last updated by  dennis da menace 16 years, 2 months ago.
  • #97612
    Bob Dowsett
    04 wr450f
    Bike was still running on last ride but got progressively more gutless especially if u gave it a gutfull of throttle it would nearly stall and basically just had nothing
    it would still start on the button and kicker but kicker was a bit harder
    Has possibly been getting progressively worse over last few rides(power wise)
    I thought my ability was just catching up to bike but no
    Took it to mechanic he had a look
    timing chain very tight on 1 side and must have jumped a tooth as couldn’t be timed properly
    What other damage could have been done considering bike was still rideable and going but a bit more like a pw 50 than a 450
    hoping there aren’t any bent valves or shit like that :( :(
    keep it in plain english as i am no engine mechanic :( :(
    #162953
    Trent
    Was it making any noise like the piston was colliding with the valves?
    Could be any one or a combination of:
    Bent valves
    Damaged head
    damaged piston
    damaged bore
    Good luck with it.
    #162954
    Bob Dowsett
    no noises that i can remmember nothing to make u think oh f*#k and stop maybe just bit throatier in the noise dept
    originally thought it may have been a carby problem
    #162955
    Well no noises eh? Thats good, please PM me the mechanic looking at it mate
    It sounds strange that it would just jump a tooth with out you noticing it, as the engine would change its note and performance straight away like a light switch
    Need more information Bob
    What might of happened is the cam sprocket/s may have slipped on the cam shaft. They are only pressed on and occasionally do this.
    My WR400 did it and the bike shop could not get it timed so he had another WR in the shop and measured the cam lobe postions and they were different. We set the cam lobes up to the same measurement as the standard WR and mine run perfectly and never moved again.
    Just a though Bob and easy to check.
    #162962
    Yes that’s it Mal, I was at Sutto’s the other day and they were talking about that and it makes far more sense then jumping teeth as I cant see how they can jump. I saw a DRZ break the spring on an auto tensioner whilst on the rev limiter and it still didnt jump a tooth. If I remember now they dont have witness marks either and you have to buy a new cam. It should only be one cam that has slipped.
    Check your PM’s Bob
    Bob Dowsett
    The bike seem to be lacking performance just had no sting when u twist the throttle
    on the last few rides that I have been on could be just in my dreams but after this incident it was most probably correct
    as said previously i was blaming the carby blocked jet or something
    we went up a couple of hills ok then about 5 mins later or so went to give it a bootful and it just groaned and nearly stalled kept riding for a while and rode it home i would have thought if anything was colliding in there that wasn’t supposed to be u would hear it ???
    cam gear slipping on shaft does make sense as it was a gradual thing ???
    but i’m no mechanic
    Have taken bike to a few local bike shops in past to get valves done and checked and so on and asked them too have a look through it and have come up with nothing wrong but i am beginning to think that most of them either don’t give a shit or want u to rebuild it there and then
    got a referral from a guy i know about a one man op that operates out of cowra and tunes race bikes
    should we pull it right down and have a look or not
    how long and how much$ would u expect to pull down look and reassemble
    Bob
    #162982
    but i’m no mechanic
    Bob
    doesnt sound good bob,
    whatever it is i hope its cheap and easy fixed
