Tips & Tricks for Levers
Home Forums Bike Preparation Tips Bike Preparation Tips Tips & Tricks for Levers
This topic contains 4 replies, has 0 voices, and was last updated by  Anonymous 17 years, 2 months ago.
  • #95133
    When you crash your bike, two of the most likely parts to get damaged are your clutch and front brake levers. Without these two levers, your race or ride could be over. Here are some simple and cheap tricks that can help you.
    1) Teflon tape:
    What you do with this is wrap a few layers of Teflon/PTFE tape (available at any home improvement or auto parts store) around your bars underneath the clutch/brake perches. Tighten your perches down snugly, but not so tight that a crash won’t move them. The idea here is that Teflon tape is slick, so it allows the perches to move on the bars, saving your levers and perches from damage when you hit the ground.
    You CAN use “rotator perches” in place of the Teflon tape, and acheive the same results. My thought on that is “why spend the money if you don’t have to?” If you want to spend the money on the rotator perches, that’s cool too.
    2) Drilling your levers:
    Eventually, you’re going to crash hard enough to break a lever, whether it’s forged or cast. By drilling a small hole in your lever about 1 inch in from the ball end, you create a weak point where the lever will snap. However, the crash only snaps off the outer inch of the lever, leaving you enough of the lever left to be usable. You’ll be able to finish your race or ride on what’s left of your lever. Some bikes (like KTM’s) and some aftermarket levers come with notches in the lever for just this purpose.
    3) Using handguards:
    We’ve all seen the wraparound style handguards that a lot of riders use. These make it almost impossible for your levers to get wrecked, but you do have to be a bit careful with these. Why? There is a chance that, in a crash, your wrist or arm could get caught between the handlebar and the guard, which is highly likely to result in a broken wrist or arm.
    The handguards that I use are the “deflector” or “roost guard” type, specifically Acerbis Uniko handguards. These guards won’t protect your levers and hands from a tree, but they CAN protect your levers in a typical crash on a track or trail. What happens is that there is a layer of plastic between the lever and the ground, so the lever usually can’t catch on any ruts, roots, tree branches, rocks, etc., that could cause the lever to break.
    We all know that there are the ARC/ASV levers available, as well as some from other companies. However, these levers are expensive, so why spend the bucks if you don’t have to? By using the tricks described above, I’ve never had a broken lever spell an end to my race or ride
    #108302
    May i be presumptuous to add Moto, if you take a tumble and break the ball end off your lever replace it ASAP, I have now got at least back to a a dull numb sensation in my knuckleless third finger on the right hand after skewering my palm with my partially broken front brake lever 20 years ago.
    I run aftermarket shorty levers on all our bikes as well, lessens the chance of Snags and allows better grip while clutching or braking, for the little person riders I always replace “big” levers with some more suited to little hands, High end BMX components are good for this, they have little reach adjustable levers on the better race bikes.
    Mr Blue
    #110216
    Sounds like good advice Bruce. I have been thinking about shorty levers for a while. Never had the chance to use them so far and see what they are like. Better grip you say, hmmm……..
    #110217
    Better Grip on the Bars with the fingers that are not tied to the long lever is what he means Moto, MX and SX riders always ride with their index or middle fingers (or a combo of both) on levers full time , so you are not wasting time getting to controls, Shorty levers make it easier on the last two fingers.
    Dave
    #116393
    Yeah, I used to run a shorty brake lever on a trials bike for a while as it helped pulling the bike about.
    I find mysel riding with my finger on each almost premanently anyway. Need to try and stop doing that. I still flick the clutch changing gear too, even when gunning it.
