Top End
Home Forums Tech Help Tech Help Top End
This topic contains 23 replies, has 0 voices, and was last updated by  Jason Green 15 years, 3 months ago.
Viewing 9 posts - 16 through 24 (of 24 total)
  • #190002
    Jason Green
    What about the petrol you are using? could it be crook fuel making it knock or ping? or am I way off? I always put in the premium unleaded stuff ;)
    #190004
    Cam chain tensioner hatto, had the same thing, freaked out at first but a little adjustment and all noise gone away.
    #190005
    arent they renowned for sh!tting cam chain tensioners??
    id go with a solid disc too hatto, better wear rate and a little more feel in the pedal i reckon…..or solid with pretty holes :laugh:
    #190009
    Hey Hatto
    Same thoughts as Menace :ohmy: Was told that the solid discs, no holes, last longer in muddy conditions??? Thats what we run.
    PS. Doubt she’d be up for a rebuild, my 525 has 12500kms on her
    #190013
    Glenn
    Hey Hatto,
    From what you are descibing it sounds like the cam chain tensioner is colapsing. Throw out your old OEM chain tensioner and replace it with one of these.
    http://www.dirttricks.com/timing_chain_tensioner.htm
    #190015
    4T first thing I’d check if there is a new “noise” or feel to the engine is Camchain tensioner.
    Been bitten before, the end result can be costly.
    #189969
    To straighten the disk I grab a thick black marker and a big arsed adjustable wrench aka “shifta”. Raise wheel, spin wheel, notice where pad scrapes, colour in the disk where you think it touches, spin wheel, if marker rubs away that’s where it touches. Utilise the wrench to bend disk a little without snapping it. Repeat until no more pad touches disk.
    #189970
    Craig Hatton
    Thanks everyone for the replies, some good thing to work on here.
    Finally got a chance to clean bike yesterday arvo, take bashplate off and find a rock, this may have been the noise because when riding after a wash, no noise was evident “Doh”
    cheers Hatto
    #190059
    Jason Green
    cheers Hatto
    HA HA :laugh: :laugh: I had to laugh when I read this after all the technical gurus rack there brains out thinking it was a major issue and it turns out to be a bloody rock. At least you don’t have to worry about it now. I remember the sound of the xr when I put on the bashplate it made the noise bounce back from the crankcase B)
