Tyre sizes??
Home Forums Tech Help Tech Help Tyre sizes??
This topic contains 7 replies, has 0 voices, and was last updated by  Anonymous 16 years, 3 months ago.
  • #97738
    I am having trouble getting my head around some tyre sizes.
    is a 4.50-18 the same as a 120/100-18 ?? If so how does that translate?
    #165404
    120 mm is the one tyre and 4.5 inches is the other and yes they are roughly the same
    #165405
    Mick as you know ones metric and one is the old imperial sizing what you have written is close enough to the same mate. The attached chart will answer all your questions
    Check this out mate
    Thanks Dave, I hadn’t even considered that the 4.50 would be an imperial measurement.
    #165407
    Check this out mate
    Thanks TB,like I said to dave,I am suprised that the imperial measurement is still used. Then again the rim diameters are still measures in inches. Stands to reason when you look at it that way.
    #165408
    The manufacturer of the imperial type is stuck in yesteryear and the metric numbers sound cooler on the metric, a 120 or 130 sounds way bigger than a 4.5, the reason I say 120 or 130 is different brands call them different sizes but they are the same size in reality, I think its easier to just say they are black and round :huh: :huh: :huh:
    #165409
    Actually the tyre in question is a Kenda.
    #165410
    Kenda are American and the yanks work in ye olde worlde. Although all the Kenda tyres I’ve seen have metric measurements. Maybe an old tyre?
