Unidirectional tyres
Home Forums General Bike Talk Unidirectional tyres
This topic contains 13 replies, has 0 voices, and was last updated by  Anonymous 17 years, 1 month ago.
  • #95870
    I have been down the shed having a bit of a cleanup and there are several used tyres in there.
    Some of them still have more tread on them than the one that is on my bike.They are all Bridgestone ED12’s which are unidirectional tyres,what happens if I put them on the other way round? The reason I ask, they have a better edge on them if put on the wrong way.
    Has anyone got any experience in this?
    #122557
    Mick, Directional tyres will have an arrow indicating the way they are designed to go and unidirectional can be put on either way, you will just move the better edge around to get more life out of the tyre, usually when you turn a uni around you get the drive back but then the braking suffers….you get nothing for nothing my friend…..are you up for a wet night ride
    #122558
    Be very wary. The bike may have a tendency to go backwards. To maintain even tyre wear on the bike, it could pay you to rotate the tyres from front to rear.
    These ideas are only theory and made not be necessarily be correct.
    #122563
    I’m with slug rotating the front/rear is the way to go :laugh:
    #122559
    On a serious note, that is what most of us frugal riders do to get more out of the tyre. In the olden days, I had been known to even cut the blocks by using a very sharp knife and WD40 as a lubricant to slice off the leading face of the knobs to give it a new sharp edge.
    #122568
    Squaring the knobs off a tyre is a good way to get a few more decent K’s out of a worn tyre. I don’t know how you were rotating tyres though???
    #122571
    Thanks guys,I never gave the braking a thought,I was only thinking of drive traction.
    Hey dave are you still getting a tyre groover?
    Oh yeah this is the context I was using the work unidirectional
    Adj. 1. unidirectional – operating or moving or allowing movement in one direction only
    #122560
    Nick Again
    Yep, I’ve even drilled holes in em and screwed bolys in to them for another ride…I claim NO responsibilty if anyone tries this and rides on blacktop!! Trust me..most things I did as a kid I have moved on from as an adult!
    #122586
    Mick, if it is an ED12 you can take to it with an angle grinder. I did with the one I gave to TB to put some square edges back on it. Didn’t help, I think the compound of ED12’s is too hard. It also nearly wore out the grinder disk doing it!
    #122589
    Has anyone ever heard the arguement that there is more traction with a half worn tyre on a hard pack track then a new sharp edge tyre?
    #122590
    Heard it. I say it depends a lot on the compound of the rubber. An awful lot. That ED12 was terrible once it got down a bit, but my Maxxis which replaced it was great, even once it was nearly shagged.
    #122561
    YEP, I heard that one from CHAMPO the wise OBT racer :laugh:
    First day I met him at Kurri MCC when he found a discarded tyre on the ground & was contemplating using it,,, can`t remember whether he took it home or not:dry:
    #122593
    i actually took home about 5 tyres that day
    we got a knobby for racytracy
    some trials tyres for dirt track’n
    a worn racing wet tyre cause it was cool
    a new ‘old school’ dirt tracker for moto’s project bike
    #122591
    It’s beacuse you have a larger contact area with the ground. This isn’t required in the slippery stuff, grippy square edged knobs are :)
