valve bucket shim question
Home Forums Tech Help Tech Help valve bucket shim question
This topic contains 11 replies, has 0 voices, and was last updated by  Greg 16 years, 8 months ago.
  • #96822
    shane
    It never ends…
    Decided to check the valve clearances while I had the Vor apart for a clean, poor old thing didn’t like to start on the magic button and I expected that the ex valves weren’t opening enough.
    Well it seems the clearances have closed up, which means the valve have recessed?
    So I took the shims out and put them in nice little bags which were labelled.
    Now that they are out, is it suitable to measure the distance between the rocker arms and the top of the valve stem, subtract the distance I want for clearance and this will give me the required shim size? Or do I have to put the shims back in and take measurements then?
    Having looked at it now I suspect that I might have to take the head off and have a look at the valves :unsure: , I take it shims come in pretty much any size?
    At what point does one say, “Nup that’s it, the valves need replacing old son!”
    #144001
    Gday Mate
    I have not been inside the Vor before but they are all similar enough to give some little input to you,
    Clearances closing….yes valves recessed or stems stretched
    As far as shims in or out , some do it both ways to get the measurements and I am not sure how yours is done, Sorry Mate:(
    At what point does one say thats it…well…Mine was a ways past taking apart and I ignored it(no money) and in the end it Won, it died gracefully and recessed so far I had no more adjustment(KTM have adjusters not shims)and the Baby would not start, So I guess that enough was enough. I would not let it get that far if I could have afforded it, , The thing will use oil and even after adjustments of shims it wont start easily.
    Good Luck Mate:) :)
    #144002
    Glenn
    shane_vor wrote:
    It never ends…
    If your valve clearances close up enough to where the bike will not start or has difficulty in starting, you may have already done damage to your engine. If for example the required spec’s are .008″ clearance and you only have 002″ clearance, the bike will start but when it warms up to operating temp the metal will expand from the heat and the .002″ will close up to the point when the valve is never fully seated. This is one cause in difficulty in starting. Possibly not as you suggested, the valve not opening far enough. Running an engine like this will eventually result in the head of the valve breaking off.
    cheers Glenn
    #144004
    Trent
    Rat,
    I’m just researching how to check the valves on my 07 250excf and the repair manual doesn’t really help much but it does mention the use of shims for adjustment. Is there a better ‘how to’for checking the valve clearances than the repair manual?
    #144007
    Bill
    Im with Blue 450 but what is the clearance and how many times have the shims been swaped for thinner ones to make a call on valve recession
    Yes you need to measure first then workout your ajustment to thickness
    #144008
    Bill
    Austblue wrote:
    Rat,
    I think its in the KTM tech help
    #144009
    Glenn
    Austblue wrote:
    Rat,
    Although this vid is not for your Kato, the concept is the same.
    #144010
    Shane do you have the clearances written down that they were before you pulled it apart? You have each shim for each valve in its own bag I gather?
    Now the first question that should have been asked do you know how many times before the valves have required shimming?
    You have owned it since new the bike, how many time have the valves been done before?
    If never then a re shim and it will be fine :)
    You home tomorrow I will call around during the day and have a chat :laugh:
    I have mics and the gear to measure the shims so we can order the correct thickness shims
    Standard call out fee but :P
    Trent
    Thanks for the offer bull!
    Sorry, what’s the ktm tech help?
    This is what it says in the repair manual:
    Checking the valve clearance
    – Use the feelø gauge 590.29.041.000 to measure the valve
    clearance:
    lntake valves 0.10 – 0.20 mm
    Exhaust valves 0.12 – O.22 mm
    – Wite down any dcviations from the specified valve clearance,
    remove the camshafts and measure the thickness of the installed
    shims. lf the measured valve clearance is too small, use thinner
    shims; if the valve clearance is too large, install thicker shims.
    Shims are available in thicknesses of 1.72 to 2.60 mm in
    graduations of 0.04 mm.
    – Check the valve clearance again after asscmbly and correct again if
    necessary,
    – Unscrew the engine locking screw, remount with the CU-seal ring
    and tighten to 20 Nm.
    I think I’m hijacking so I might just start another thread.
    #144013
    shane
    No dramas with this hijack, it’s all the same topic and one never knows when I’ll swing my leg over a pumpkin!!!!!
    Sounds like an idea TB. I was gonna wait till I got to work to measure the shims but a house call sounds like the goods! Yes, aware of the usual call out fee!;) and I’ll be home all day! You’ll probably end up saving me pulling the head off during my holidays and mowing the bloody lawns instead! (Missus’ll love that!!!)
    I’m about 99% sure the valves hadn’t been done before…but my memory is weak…:huh:
    #144017
    If the valves haven’t been done before or even once before they will be able to be adjusted for sure. Don’t worry about all the head of, valve failure talk it will be all good :laugh:
    Bill
    in the fourm underr KTM Bikes 3rd one down by moto
