This topic contains 18 replies, has 0 voices, and was last updated by ian 12 years, 5 months ago.
May 25, 2010 at 4:58 am #98492
OK, I am after your wheel bearings sizes please. What this means is when you next change your wheel bearings can you please get the numbers of the bearings and post them here on this thread example
XR650R 2005 model
Rear wheel – 6204 and 6203
Front wheel – 6202 x 2
If you are able to get numbers of the seals please post those as well. Over a period of time I hope to get enough information together to have a bearing shop we have in mind set up with bearing and maybe seal kits both able to be purchased separately or together. You will be able to ring up and order the kit and they will send them to you maybe even COD. If you have ever bought your wheel bearings from a bearing shop you will know they are heaps cheaper then most bike shops
This is of course if people help and provide their bearing numbers. This will help everybody. I will also source numbers from other areas and post them as well.
May 25, 2010 at 5:08 am #179976XR650R rear wheel seals.
Sprocket side OIL SEAL (28X47.2X7) 91252-MC4-013
Disc side OIL SEAL (28X42X7) 91257-230-003
May 25, 2010 at 5:14 am #179977here you go TB, did my rear when i put the new tyre on for Kenda.
KTM LC4-E 2001 build 2002 model
rear
numbers on the seal: HCH brand, 6205-2R5 x 2 and 1x that just has 6205 on the seal but is a double race bearing,the 3 bearings are all the same internal and external measurements. and i got mine form a shop that stocks bearings, they had the 6205-2R5 in stock but had to get the double race one in over night.
new bearings are KBC 6025DD x2 and i’ll have to look up the KBC number for the 1x double race one if i still have the box floating around.
hope this is what you are after.
a side note/ Q? is there a difference in quality as to brands? i know price can make a difference, some times. but what about brands?
May 25, 2010 at 6:34 am #179984Bloody great Idea TB, I’ll have a look at the old ones this evening, as they all the same for the YZ/WR range from 98ish to current.
If someone knows the bearing sizes for “02-“04 yamaha YZ/WR linkages I’d be grateful….
In the middle of a rearend refurbishment, and am ashamed to state that I left it far too late this time…..
May 25, 2010 at 7:13 am #179988Mr Blue wrote:
Quote:Bloody great Idea TB, I’ll have a look at the old ones this evening, as they all the same for the YZ/WR range from 98ish to current.If someone knows the bearing sizes for “02-“04 yamaha YZ/WR linkages I’d be grateful….
apparrently they aren’t all the same when i got mine there is a change in the o5 model and some of the very late 04 models according to yamaha
i didn’t have the no of one of the bearings and it took 2 goes through yamaha and still the wrong ones so i took id and od and went to regional bearings
i’ll post my no’s when i get around to itMay 25, 2010 at 7:23 am #17998908 ktm530 front wheel smt 6906rs bearing- seal nak tc 35 47 7 16 back nsk k33 6005v bearing seal apears to be same as front. head stem l45410 m2 tf x0297 on outer andl45449 m2 sy x0297 on iner part of bearing hope that is right had some different brand bearins with diferent letters on the end of numbers ?.good to have spares in the shed
May 25, 2010 at 7:34 am #179992just to confuse things the box for head stem bearing has nachi h-l45449/10 k0605 the box for back wheel bearing nsk 6005vvcm ns7s and than 808
May 25, 2010 at 8:46 am #179996OK this will be the offical list and I will move it thoughtout the thread
Honda BearingsYear Front Rear
XR650 00-07 60032RS x 2 62042RS x 2XR250 96-08 60032RS x 2 63032RS x 2
XR400 96-08 60032RS x 2 63032RS x 2
Honda SealsXR650 00-07
Disc side OIL SEAL (28X42X7) 91257-230-003SuzukiYear Front Rear
DR400 All ??? 6004 x 2 & 6204 x 1YamahaYear Front Rear
KawaskiYear Front Rear
KTMYear Front Rear
530 08 6906rs 6005vHuskyYear Front Rear
May 25, 2010 at 1:23 pm #179978I know some say different model wr450’s use different bearings, but from what I have seen its the seals/spacers that change bearings stay the same… Standard yamaha wheel bearings normally don’t come with seals so i usually use sealed bearings.
Alloy frame and steel frame use the same headset bearings too
04,05 07,08,09,10 WR 450/250 (haven’t had an 06 or 03 but would imagine they are the same)
Front 6904 LLU x 2
Rear 62/22 LLU X 1
60/22 LLU X 1Top Headset Bearing 320/28X
Bottom Headset Bearing CR0643L
I have seal sizes I will update, next time I’m in the shop
May 25, 2010 at 11:20 pm #180024badbowie wrote:
Quote:WR 450/250Bottom Headset Bearing CR0643L
The bottom headset bearing with this number includes the lower seal
May 26, 2010 at 12:58 am #180038Rear linkage bearings for “02-“04 Yamaha YZs and WRs.
NB- these sizes are specific only to the models above, prior to, and after which they changed
NRSC-20.00×27.00×30.00- ( over $26 each for bare bearing-not that cheap )
Wheel bearings for
YZ125 99-09
YZ250 99-09
YZ250F 01-08
WR250F 01-09
YZ400F 99
WR400F 99-02
YZ426F 00-02
WR426F 01-02
YZ450F 03-08Front Wheel – Bearings: 6904-RS
Seals: 25x38x7Rear Wheel – Bearings: 62/22RD, 60/22RD
Seals: 30x50x7, 30x44x5May 26, 2010 at 4:13 am #179979Haan Wheels for WR
Front with speedo drive
Bearing
6904 RS x1
6004 RS x1Seal
25 42 7 x1
Speedo drive seal unsure at this stage, possibly a yamaha specialRear with cush drive
bearing
60/28 RSI x3Seal
32 52 7 x3May 27, 2010 at 5:42 am #179990Husaberg FE550E 2005 – 2007
Front Wheel
Husaberg P/N 0625069068 GR.BALL BEARING.6906 DDU2CG23S6NM x 2
0760354771 SHAFT SEAL RING 35X47X7 TC x 2Rear Wheel
Husaberg P/N 0625060058 GR.BALL BEARING.6005 DDU2CG23S6NM x 2
0472047175 CIRCLIP DIN0472-47X1,75 x 1
0760324771 SHAFT SEAL RING 32X47X7 BSL 2May 27, 2010 at 10:53 am #180152GASGAS 300 and probably all other capacities
rear wheel bearing and seals 2 x 6004 2RS
1 x 6005 25R1 C3 or in laymans terms a 6005 2RS C3 clearance bearing32 x 47 x 7 seal
25 x 42 x 7 sealfronts
2 x 6905 2RS
30x42x7mm (TC 30452)
June 23, 2010 at 3:25 am #180193bump
