Water pump leaks
This topic contains 2 replies, has 0 voices, and was last updated by  Peter Chadwick 14 years, 1 month ago.
  • #100919
    Just servicing the bike for the ride at wingello on tuesday & i noticed the water pump leaking. The seal is loose on the shaft & I know about securing the new one in, but the problem is I can’t get a seal & side cover gasket before tuesday.
    Does anyone know where I can get one over the weekend. Im in the Ingleburn area. :(
    #214393
    That sux mate, Monday try Westerns at Penrith or Action Suzuki at Parramatta
    Thanks Trailboss, I allready rang action & it seems nobody likes to keep to much in stock when you can just order it in.
    Wingello has been put back to friday so I should be ok by then.
