Wet versus Dry lube
Home Forums Tech Help Tech Help Wet versus Dry lube
This topic contains 18 replies, has 0 voices, and was last updated by  Bruce Curtis 15 years, 9 months ago.
  • #181565
    I have had a few rides now on the Motorex 622 and I like it a lot. The chain links are much smoother than with the wax lube and much quieter too.
    At the end of the ride it seemed like there was still plenty on there and I got it real wet during the ride so it is thumbs up from me.
    Once again OBT has saved me a lot of time and money. :)
    Bill
    I use silicon spray on my chains, have done for the last 3 years and have no problems.
    3-IN-ONEĀ® Professional Silicone Spray Lubricant
    Quick-drying no-mess high-performance lubrication and corrosion protection
    3-IN-ONE Professional Silicone Spray Lubricant provides high-performance lubrication and corrosion protection, in a quick-drying no-mess formula. It’s safe for use on metal, rubber, vinyl, wood, and much more.
    Lubricates: Doors, locks, hinges, belts, windows, latches, zippers, switches, fishing equipment, tools, chains, belts, sports equipment, lawn equipment, valves, linkages, pulleys, fans and more.
    Protects: Electrical parts such as distributors, ignition wires and sparkplugs. It can also be used to protect guns, boots, tools, pool and marine equipment
    #182313
    AND IT’S SHINY SHINY ON PLASTIC TOO….. ;)
    I use it for not the chain, but to coat the bike pre-ride to help stop crud sticking on everything.
    #181464
    I was thrown a can of Motul chain lube at the Watagans Rally presentation :woohoo:
    It’s not Motorex but may be just as good :unsure:
    Based on the information gathered from this thread about chain lube vs WD40 i will change my ways and give it a go :)
    Rebore
