Home › Forums › General Bike Talk › What did you do to your bike today?
This topic contains 732 replies, has 0 voices, and was last updated by alan 10 years, 7 months ago.
April 21, 2013 at 8:24 pm #240158
Crashed it ………… again……… :blush:
April 29, 2013 at 4:41 am #227478Took Antonio to the doctors (put the Husky in at the mechanic)
Leaking rear brake master cylinder
Missing front radiator guard :blush:
Mode switch being installed so I can decrease the power when I don’t need it.
F*&I(NNG clutch being stripped completely and if all else fails a ktm one being put on! Going to try and change piston in mount, hopefully that makes it lighter.oh and bit of free play being put on throttle… :blush: brain to hand co-ordination still crap :whistle:
April 29, 2013 at 7:27 am #240570Fitted a sunline MDX clutch lever to the 300exc.
I have broken or bent 3 levers in 4 rides
April 29, 2013 at 7:52 am #227479pulling bike to pieces, because im bored and cant ride it still
April 29, 2013 at 8:32 am #240579capri935 wrote:Fitted a sunline MDX clutch lever to the 300exc.I have broken or bent 3 levers in 4 rides
You shouldn’t let your bike fall off the stand when you are warming it up
I let the air out of my forks, lubed the chain and its ready for a Thursday arvo session.
April 29, 2013 at 8:38 am #240583LC4skin wrote:capri935 wrote:Fitted a sunline MDX clutch lever to the 300exc.I have broken or bent 3 levers in 4 rides
Thanks for reminding me Matt, and pointing out my stupidity to everyone else. :silly:
April 29, 2013 at 8:48 am #240584At least it was soft mud and didn’t break the lever this time.
April 30, 2013 at 10:34 am #227480Just headed down to the garage to change my front brakes pads …. this was the first time … not that confident on the tools so had done a bit of research was all set ready to go … then noticed my fork seal is leaking DANG IT!!
April 30, 2013 at 8:23 pm #240673After my little come off up in Werrikimbe, I had a bent brake pedal on the XR. Thanks to the brake snake it wasn’t bent too badly but bent none the less.
I had visions of using a heat gun to warm up the cast alloy a little and bend it back into shape but took TB’s advice instead and did a cold bend on it and it worked a treat.
I then made a new brake snake, this time using wire trace instead of 200lb Jinkai marlin trace.
May 2, 2013 at 7:26 am #240674Machined up some new foot peg mounts (well the machind did) Changed the offset down 10mm for my long legs so hopfully l can crip the bike better. Will find out on Saturday.
[attachment=3831]P5020147_zps7fc7238a.jpg[/attachment]
Time to program up some new foot pegs as these Honda ones are crap in the wet :S
Thrillseeker
May 2, 2013 at 7:47 am #227481hi micknmeld just a quick question about the brakesnake wouldnt it be better to use the marlin [nilon ?] trace compared to wire trace as it gives abit more ,if the snake is to ridgeid wouldnt it put alot of stress on your bash plate [ bolts ]
wolfie
May 2, 2013 at 7:47 am #227482nice job thrillseeker
May 2, 2013 at 8:22 am #240899Thrillseeker wrote:Machined up some new foot peg mounts (well the machind did) Changed the offset down 10mm for my long legs so hopfully l can crip the bike better. Will find out on Saturday.[attachment=3831]P5020147_zps7fc7238a.jpg[/attachment]
Thrillseeker
Nice work mate!
Do want to sell a pair of those and do you think you could get away with 15mm?STM
May 2, 2013 at 8:41 am #240902Hey STM
Yep could sell a set no worries. They would come with pins and spacers also.
I will give them a good test on Saturday on some tree stumps and rocks first.
I think 15mm would fit ok.Lets see you them work first.
Thrillseeker.
May 2, 2013 at 8:34 pm #240901wolfie wrote:hi micknmeld just a quick question about the brakesnake wouldnt it be better to use the marlin [nilon ?] trace compared to wire trace as it gives abit more ,if the snake is to ridgeid wouldnt it put alot of stress on your bash plate [ bolts ]wolfie
I reckon she’ll be right Wolfie, those Whipps bash plates for the XR650 are pretty tough. I think the brake pedal will flatten before it will pull the bash plate bolts. That bash plate has taken some serious knocks in the past.
