What did you do to your bike today?
Home Forums General Bike Talk What did you do to your bike today?
This topic contains 732 replies, has 0 voices, and was last updated by  alan 10 years, 6 months ago.
Viewing 15 posts - 31 through 45 (of 745 total)
  • #227649
    Steve Wyeth
    Ollie wrote:
    Yes I am a SEAman not a SEMEN :laugh: (you idjit) :laugh: and the forks are for the Gasgas B) I got some corrosion on the bottom of one of my Marzocchi fork sliders and have been told the Showa option is the way to go. All I need now is someone who is handy on a Mill to bore out my triple clamps a poofteenth ;) anyone know anyone willing to have a go at mates rates :blush:
    So they’re slightly bigger are they. Should have gone the Fonda triples as well :) I thought you’d have peeps at hand to that sort of stuff?
    #227656
    Being sensible (for a change :laugh: ) wouldn’t rechroming one fork tube be cheaper and less hassle maybe :huh: unless the forks aren’t as good as the Showas and the Honda brakes are good stuff as Mr Blue will tell you. Is it a common conversation Ollie?
    Steve Wyeth
    I thought the same too. I’m betting those Showa’s will be much better than the gasser forks too. The Showa’s I’ve ridden on were all better than my previous KTM’s but I’m getting the CC WP forks dialled in on the Berg I think they are just as good. Shame it took 8 years to catch up!
    #227407
    Leo.C
    well not today but Sunday, I seized mine B) (trumps). Then dropped the black metallic paint looking oil :pinch: , tore it apart taking off the cylinder, cried, had to tool out the piston pin from what was left of the piston :huh: , cried, took apart the bottom end and removed parts of the piston skirt, cried, removed the oil pump which looked like it had been sandblasted :blink: , swore then cried, took off the idle gear and the back end of the counter balancer shaft came with…. cried.
    So out of anger, like in the movies when some bastard gets carried away and keeps punching someone long after they lose consciousness, I stripped the rest of her down to nuts and bolts, flushed out the frame, dropped it off to get get de-dented (previous owner) and painted, dropped the barrel off at Pro Bore in Pt. Mac. And to make myself feel better did a bit of retail therapy, bought a new oil pump, new kick start assembly counter balancer shaft, 86mm forged piston kit, complete gasket kit with oil seals. So now im broke but happy knowing all my goodies are in the post and with any luck just about all back together in 2-3 weeks.
    And thats what I did to/ with my bike not today but yesterday. :laugh: :laugh: :laugh:
    #227408
    Mike Wyeth
    Tonight i’m going to start rebuilding toms engine as the new barrel has arrived,new piston and rings, check the valve clearances and hopefully have it back together for the weekend.
    #227706
    Steve Wyeth
    And what’s Tom doing while this is going on, at Morgan’s I suppose :D The 490 kit look the goods?
    #227708
    It obviously a 4T. What bike is it? Jetting issue or riding it like it’s stolen until it locks up (like any 4T should)?
    #227756
    Steve Wyeth
    Probably a 400/450 then. 4t’s typically have smaller piston skirts and since the skirt was found in the bottom end and there was no mention of anything else to suggest 4t I though it less likely it was a 4t. Piston size would suggest otherwise though.
    #227758
    How many 2T bikes have an oil pump Moto? :D (oil injection aside)
    … and a counter balancer?
    #227650
    Peter Horn
    I’ve got a couple of rat tail files, I’ll give it a shot for you Ollie, after all how hard can it be??
    #227766
    Steve Wyeth
    I had to go read it two more times to see where it mentioned that! :P :whistle:
    My bad!
    #227682
    Well that will do me Ollie :laugh: you ride a Gasser with a Honda clutch, Honda forks, Honda wheel, Honda Brakes etc
    Must be a good thing those early Gassers :S Just get the whole package mate everybody else is :laugh:
    You have the XR your halfway there come clean no one will judge you mate your with friends 👿 :laugh: :laugh:
    STM is right but the Showas are good kit mate ;)
    I probably would buy a F#@^ing Honda if they still made 2 strokes :angry: after seeing all the issues these blown up exspensive 4T’s are having no thanks.
    The Showa’s are a common swap, the bomb would have been KYB CC forks off a late model YZ but they cost a bit more. I could have gotten away with rechroming but the Marzocchi’s have a black nitride coating on them as well so it woud have been both legs to be done. Apparently the Marzocchi’s shiver 45’s are a copy of a 92 model Showa (like I had on my 92 Husky 360) In all honesty the new showa’s should outperform the Marzocci;s in every aspect. The problem with the CRF brakes is it is only a 240mm disk Why? I will have to look at trying to get a 260 mm upgrade from somewhere especially since I need as much front end braking as I can get. (remember its only my little finger applying the force 😆 )
    I do have access to Machine shops but Im not at home often enough to utilise them,I would just prefer to get a professional mob to do it right the first time.
    I think Bulls Wools bike is a XR400 ?
    Honda 2T I would buy one too if registered. Pigs will never fly.
    An adapter plate for the caliper would do it Ollie?
    #227771
    I got an early knock off and got stuck into a bit of maintenance , firstly and most importantly I fitted a new billet fuel cap as the original is obviously inferior and had to be changed :D.
    Then I pulled off my front wheel as the moose I fitted 4 1/2 months ago seemed very very soft and unstable on the Bello – Lowanna ride and sure enough it was split all over the place and mushy :( . This can’t be a commen problem after that amount of time so it must have been something I did ??? Don’t know what ??
    I’ve got a new S12 coming this week so I wanted to have the wheel stripped and ready , on inspection I found one of my front bearings seized solid so I did both bearings and seals and the brake pads so I know the front ends all good for a while :)
    I used the air filter cleaner I got from Lefty and it’s great stuff and cleaned my filter in no time ;)
    Oil change and air filter oil and fit tomorrow ( maybe ) !!
    Sounds like its ready for a ride mate!! What about the TK ride?? ;)
