Home › Forums › General Bike Talk › What did you do to your bike today?
This topic contains 732 replies, has 0 voices, and was last updated by alan 10 years, 6 months ago.
October 19, 2013 at 5:17 am #227569
I might throw on the pannier rack ready for next weekend later today, hopefully the Wolfman Bags will turn up by mid week so I can fit & check them out :whistle:
A slight reshuffle in the way I pack stuff is needed I think as the new tent arrived on friday
October 19, 2013 at 7:02 am #227570washed the husky 50 and serviced, washed husky 310 and found a cpl bolts missing again :angry: , and washed my ktm 450 serviced it and put a new s12 on the rear and also noticed I need a new front ,what is everybody liking on the front ?
October 19, 2013 at 7:59 am #250850i like mx51 fronts but the side nobs brake of also m12 mitchelins are okay fronts don t like the s12 front just my opionion looks like a dry hot summer coming up reckon most intermediat ones would be okay
October 19, 2013 at 9:30 am #250851October 19, 2013 at 9:47 am #250857October 19, 2013 at 11:04 am #250852wolfie wrote:washed the husky 50 and serviced, washed husky 310 and found a cpl bolts missing again :angry: , and washed my ktm 450 serviced it and put a new s12 on the rear and also noticed I need a new front ,what is everybody liking on the front ?M12 for me on front wouldnt use anything else
October 19, 2013 at 11:47 am #250858October 19, 2013 at 8:18 pm #250859My old Postie used to do that
I thought they all did it. :laugh:
I think its the seal behind the sprocket, I controlled the leak by using a tray.
MurphOctober 19, 2013 at 8:18 pm #250860Yes TB and Eags, a valuable skill to have when out on the trails although I am not sure whether I changed these tyres with much skill, more like bumbled my way through the process but there on :silly: They are replacing the ones you did for me TB some 5000 and a bit klms ago so was in need of new ones 😆
Knuckles didn’t suffer any damage Eags which is a bonus,mind you I just plodded along and didn’t rush the job.
Is it hard to change the sprockets and chain Eags as I think mine may need replacing as the chain came off once on the recent ride I did with PTW and had to tighten it 3 or 4 times on the tripCheers James
October 19, 2013 at 11:00 pm #227571Easy job to do the sprockets & chain mate, just a few hints to help you along.
With chain still on, Use a piece of pipe (I use trolley jack handle) thru the rear wheel to lock under the swingarm.
This enables you to undo the front sprocket nut/bolt (different bikes have different sprocket setups).
Always use new bolts and nuts when fitting the new rear sprocket, don`t overtighten sprocket bolts because they will stretch :whistle:Fit new front sprocket but nut/bolts hand tight only.
Fit new chain being careful to set the correct length to suit your bike , use chain breaker to remove links (I have used a grinder to grind rivet heads in the past) A breaker is a better investment $50 for a toolbag size one.
Be sure to install the master link with the open end of the clip facing the rear of the bike when it passes over the front sprocket.Retension the front sprocket nut/bolt by using the pipe method again, but this time locking on the top of swingarm.
Use a small screwdriver in between the chain & sprocket, turn wheel in reverse and tension axle nut, then remove screwdriver,,,
ALL DONE
Sorry I have no pics to explain these, might be able to take some examples later today if you need James
October 20, 2013 at 12:21 am #250866EAGLE`02 wrote:Easy job to do the sprockets & chain mate, just a few hints to help you along.With chain still on, Use a piece of pipe (I use trolley jack handle) thru the rear wheel to lock under the swingarm.
ALL DONE
Ring me James :laugh: :laugh:
October 20, 2013 at 1:41 am #227572Yeah James,,,
Ring the OBT Tenere Guru
:laugh:He will even do it for you
October 20, 2013 at 2:15 am #250869EAGLE`02 wrote:Yeah James,,,
Nah not really, its just that you don’t need new rear sprocket nuts and stuff with the Tenere and the front sprocket nut is 32mm and not many people have a socket that big. Also the lock tab normally needs replacing and I have a few new ones. I also have a few new chains that come on them, they are good chains but I replace them because they aren’t gold :laugh: :laugh: Also its probably cush drive bearing time
That is why I said ring me, the rest of it was all good stuff
October 20, 2013 at 4:44 am #250873I did my front sprocket today dr650 put 15 tooth on im not sure what the back is but the gearing is good very easy job to do only 6 bolts and rear wheel to undo $29 from mud and tar wauchope btw they have changed owners. the new guys seem good. very friendly dr just tuned by protek chestnut rd 27.5hp it goes really well now just ask the king lol
October 20, 2013 at 4:57 am #250879https://www.dropbox.com/lightbox/photos/c/UgVTXcpUyQYw8b6
why does drop box not work?
