Home › Forums › General Bike Talk › What did you do to your bike today?
This topic contains 732 replies, has 0 voices, and was last updated by alan 10 years, 6 months ago.
December 7, 2013 at 3:49 am #252305Teknik wrote:Give me a call if you can’t get that KTM right.
NickNo worries
I’ll have a little play firstCheers nick
December 7, 2013 at 4:53 am #252298——h—— wrote:Just got home and fitted suspension that Tekniks lowered and re valved for me
Looks good so far I can touch the ground at leastJust have a little head shake on the hwy and grip has gone on the corners in the scrub so I’ve got a couple of days tweaking the clickers, if this fails I’ll give them a call for some advice
Verry happy with their service
You have headshake, no grip and it took over a month, whats to be happy about??? :huh: :huh:
December 7, 2013 at 5:36 am #252306LC4skin wrote:——h—— wrote:Just got home and fitted suspension that Tekniks lowered and re valved for me
He can ride again mr 4skin.. That’s the main thing its out of the shed and in the bush again…
No grip sounds like fun to me be carefull H
December 7, 2013 at 6:58 am #227578Slowly sorting it out
May be 15 psi too much in the frontDecember 7, 2013 at 7:01 am #227579Lol and just to clarify the suspension turned up 3 weeks before I got home so the delay was me earning the green stuff to be able to put more stuff on the bike
Vicious circle ayDecember 26, 2013 at 5:39 am #252307Started mine after it has been sitting idle for 4 months. Re-routed one of the “breather” hoses I had run into the air box that turned out to be one of the carny overflow hoses. Every time I dropped it on the right hand side it would start to fill the air box with fuel.
I will grab a new air filter for it tomorrow and be ready to go and play.
December 26, 2013 at 6:43 am #252758Jeffro wrote:Started mine after it has been sitting idle for 4 months. Re-routed one of the “breather” hoses I had run into the air box that turned out to be one of the carny overflow hoses. Every time I dropped it on the right hand side it would start to fill the air box with fuel.I will grab a new air filter for it tomorrow and be ready to go and play.
you still over at Thornton Jeffro? if your chasing an airfilter the shop will be open tomorrow im not back until the 2nd but Dan &Matt will be there
January 10, 2014 at 7:04 am #227580Just threw on a brand new Pirelli scorpion on the rear, washed and serviced.
Looking to ride nowJanuary 11, 2014 at 12:49 am #227581Repaired a hole in my ignition cover with metal putty after a rock went through it….
Put a mx51 on the front, had an extraX on there that lasted 2 rides- tyre wall got a 2cm split in it… not having much luck with tyres lately….. :huh:
January 12, 2014 at 5:22 am #227582New front brake pads, new SSB battery, cleaned the airbox (very dirty!) new spark plug, new rear brake lever (bent the old one), clean, grease, chain tighten, general check over. Happy days
January 12, 2014 at 5:44 am #253121I put mine in storage for the next 3 months, but not before O found a split in the clutch cover plate. I will have to remember that when I get back.
January 12, 2014 at 6:15 am #227583Dropped oil pulled clutch cover – spent the next 2 hours removing baked gasket and ruining case paint job in the process
Replaced clutch drive plates and springs . New clutch cable Left old one in place out of sheer laziness
Fresh oil and filter, Adjusted valves .. Adjusted valves again
Realized battery was flatSaid fuck it it can wait till monday – Open beer
January 25, 2014 at 12:03 am #253124Installed the tubliss system in the rear of the 300 last night, still holding air this morning :woohoo: :woohoo:
Will do the front Monday maybe. No more pinch flats.
January 25, 2014 at 4:37 am #227584Found a missing bolt in the rear sprocket so replaced all and re tensioned any bolt I could get to
January 25, 2014 at 6:33 am #253533MrSquiggle wrote:Installed the tubliss system in the rear of the 300 last night, still holding air this morning :woohoo: :woohoo:Will do the front Monday maybe. No more pinch flats.
Pinch flats still happen when the tire hits the alloy rim lock, they are just quicker and easier to fix with the plugs
