What did you do to your bike today?
Home Forums General Bike Talk What did you do to your bike today?
This topic contains 732 replies, has 0 voices, and was last updated by  alan 10 years, 6 months ago.
Viewing 15 posts - 121 through 135 (of 745 total)
  • #228952
    Made up a mounting bracket and fitted a Vapor speedo. Still have to wire it up yet though.
    #228950
    LC4skin wrote:
    I’m not a goose I know how to tighten bolts.
    The bolts must have been faulty or over-stressed because the ones I replaced them with could be tightened heaps tighter if need be with no problems.
    you are a GOOSE
    :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
    #228959
    I know this isn’t a tech thread Boony so you might get away with talking shit but you can still piss off
    #228960
    :woohoo: :woohoo: 😆 😆 😆 😆 😆 😆 😆 😆
    #228961
    wayne
    Put my starter moter back together on my 2010/exc 300 ,check out slavens racing for detailed info on how to put them together,im a ludit with mech things but all seemed to work out, dont know if works yet ,will try it out on the weekend.
    #228971
    Put new seals in the KTM forks and found that probably Terry Hayes has had these forks because there is a different compression piston and only one DU bush on the slider (should have two with a spacer between them)
    They work good enough though
    #228975
    Put on a new chain and sprockets
    looks like 1850kms you get out of chain and sprockets. :cheer:
    You do see the sore tooth. :huh:
    Hows this I got these extras when I bought the bike and when I went to fit the chain today some one had already cut the chain 3 links short :angry: :huh: so had to get another joining link. :dry:
    And a new back tyre IRC M5B. Not quite the tyre for these dry conditions but it might rain :P
    #229013
    ian
    to my boys ktm 50 p i ssed the plastic bushings (which were flogged out and had a lot of movement in the swingarm)they have in the swingarm and got a mate to machine up a set of brass bushings for it went to a 10 wt oil with his forks cause they were like a trampoline, and tomorrow i pick up my forks for the cr from promoto after having them revalved, testing them out at singleton track on sunday , cant wait
    #229017
    just put fuel in it and found a stuffed back wheel bearing put a second hand one in i had lying around the shed all good.reckon you have to no how to do a bit of mechanican to own a ktm seem to work on it everytime i ride it
    #229096
    #229101
    maybe i should get a yamaha hay(love there reliability but not sure about the ridability bobs cracks) you will find out about hondas soon singletrackmind there as bad or worse than ktms :whistle:
    #229102
    I read your post but then I was distracted by your signature.
    “to old to fat to slow but still out there and talking shit”
    Now I am not sure what to believe :laugh:
    good point crfs are great to ride hay
    #229104
    Changed the jetting last night to try and save some fuel and gain more low down power. Test ride today in tight singles.
    Nice and crisp with heaps of power (maybe to much) :ohmy: comes onto the pipe a bit to strong for the tight nasty stuff.
    Still uses a shit load of fuel. 48km and about 0.5L off reserve. :( Might drop the main jet down a couple of sizes.
    #229117
    Peter Horn
    t
    Is that the Gaser Mal?
    Maybe the throttle control needs backing off? :woohoo:
    Maybe not all your fuel is going thru the motor, have you looked at float heights, might be losing fuel out the bowl vent lines, just a thought, the fuel use sounds excessive ….
