This topic contains 25 replies, has 0 voices, and was last updated by Alex 12 years, 7 months ago.
July 29, 2013 at 8:05 am #103070
Ok well just asking what sprocket ratios people are running.
I’ve just put 13 on the front and 50 on the rear.
It had a 50 on the rear when I got it but cant remember if it was a 13 or 14 on the front.
I did change the rear to a 46 and at one time there was a 14 on the front, not sure if I put it on or it was already on it.
So what do we have running around out there?????
July 29, 2013 at 8:21 am #247225No idea Boze, only done 110 hrs on it since I got it, think I adjusted it once or twice but never looked. The old girl rocks along so it sort of in the I don’t really care catergory.
July 29, 2013 at 8:27 am #247229Running 14-51 on the 450x,smoothed the power delivery out and a bit more top end.
July 29, 2013 at 8:35 am #247230the rookie wrote:Running 14-51 on the 450x,smoothed the power delivery out and a bit more top end.Thats music to my ears , the 450x I just bought had an arm wrenching 13-53 to do the Mexican Rip to the Tip ride but tonight I fitted 14-51 in the hope to make it a bit more singles friendly !!!
I’m also running 14-51 on the 250x which is spot on
July 29, 2013 at 8:50 am #247233You need to compare same for same Boze eg: KTM 300 for KTM 300
Bikes have different gear ratios internally that differ and create a different counter shaft final drive ratio
Just cause a 14/48 works on a XR 400 it will be all out of sorts on a KTM 400 more than likelyTB
July 29, 2013 at 8:53 am #247235KTM 450 SX
Was 14-52
Now 14-50
Doesn’t seem as hell bent on spitting me off the back of the dam thing nowJuly 29, 2013 at 8:54 am #247236Trailboss wrote:You need to compare same for same Boze eg: KTM 300 for KTM 300Bikes have different gear ratios internally that differ and create a different counter shaft final drive ratio
Beat me to it TB. Stock on a DRZ250 is 14/42 and I’m running 14/46. Means nothing to anyone except another DRZ250 rider.
July 29, 2013 at 10:00 am #247237Yeh point taken TB.
But so far we got 14-50, 52. Mostly Honda.After the quick lap around the paddock and up the road I’m thinking I should have put a 14 on the front. But we will see how the bike handles it on Sunday. I know the front wheel is going to get more air time :woohoo: I’ll just see if I can control the throttle (think with brain not right hand).
Oh its on an 08 KTM 530
Thanks guys
July 29, 2013 at 10:10 am #247226Hey boze
I run 15-52 on my 530. Still gets me up murphs basin runs but gives me a decent transport speed
July 29, 2013 at 10:20 am #247246hay boze i found 14 50 okay but favoured 14 52 on my last bike 08 530 be interesting how 13 50 will go
July 29, 2013 at 10:24 am #247248Husaberg FE570 running 13 – 52
July 29, 2013 at 10:24 am #247247tryhard wrote:Hey boze
Mmm that sounds high. But ok.
I was happy with the 13-46 I had. I can remember putting the 46 on to tame it as the front did lift a bit and to run over to Gunnedah (80km). Just trail riding it a lot now & looking for happy medium.
Thanks
July 29, 2013 at 10:29 am #247249white rocket wrote:hay boze i found 14 50 okay but favoured 14 52 on my last bike 08 530 be interesting how 13 50 will goWell I’m thinking if I’m playing sweep they better be ready.
July 29, 2013 at 10:29 am #24725115-52 is about the same as a 14-49 give or take a bit. Gives about 157 top out so will cruise at 110-120
July 29, 2013 at 10:35 am #247254tryhard wrote:15-52 is about the same as a 14-49 give or take a bit. Gives about 157 top out so will cruise at 110-120Ok so what you think 13-50 will be like then. Top out 120 cruise 80
