What Tape?
Home Forums Tech Help Tech Help What Tape?
This topic contains 18 replies, has 0 voices, and was last updated by  Greg 16 years, 8 months ago.
  • #144687
    Does it work Ollie, cause a couple of us tried in when went to Cape York in 2004 and I still got a flat, small pinch flat and you have had a run of flats as long as I have known you on both the bikes I have been on rides with you (RMX and GAS GAS so its not just a rim lock problem) I am interested as I see it all the time and didnt know anyone using it and would use in my rear when not running mousse compatible tyres
    The flats I got on the RMX were without the slime (both fronts)
    One HD tube and the spare normal duty.
    The flats I got on the Gasser were both rear One was at Bulls when I was installing a new tyre and pinched it, fixed it with a patch. The second time was the rear again and the rimlock wore a hole in the tube,again no slime. I have since put slime front and rear and have not had any flats. It will be interesting to see my front tube as it has taken some big bone jarring hits(you know the type:ohmy: ) and has not gone flat yet. Time will tell I guess
    Electrical tape it will be then. Kylie bought me a 10 pack on the weekend:)
    Thanks for your help Old Bulls;)
    #144701
    Cheers will watch and check it out Ollie
