Wheel Bearing Removal.
Home Forums Tech Help Tech Help Wheel Bearing Removal.
This topic contains 15 replies, has 0 voices, and was last updated by  murph the surf 14 years, 9 months ago.
Viewing 16 post (of 16 total)
  • #200699
    Ollie wrote:
    Yep Aaron, you will need a Dolly, I use a steel rod about 300mm long and 12mm diameter. Make sure it has a nice sharp edge. Poke the dolly down thru the spacer and push it to one side to expose the bearing. Give it a nice firm hit with the trusty 2lb ball pein hammer then move the spacer to the other side and do the same again. You can make the job a bit easier by warming up the hub with a heat gun. When the bearing comes out remove the spacer flip the wheel over and do the same to remove that one.
    Those Yamaha front bearings are piss weak in my opinion too small for the application. I remove the seals blow out the standard grease with compressed air repack with quality grease then put the seals back on. Get much better life from them.
    Don’t under estimate Ollie’s comment. The aluminium of the hub expands more than the steel of the bearing and can make a BIG difference.
    I realize its a bit late now but may help someone else ;)
    Regarding the grease, IMO you can never have too much lubrication :)
