which chain?
Home Forums Tech Help Tech Help which chain?
This topic contains 6 replies, has 0 voices, and was last updated by  murph the surf 13 years, 1 month ago.
  • #102445
    The xr 500 is in need of a chain for the upcoming ride for Down Syndrome. Any suggestion on which one to use?
    Thank you
    Shorten the dogs chain and use that. :laugh: :laugh:
    RK X-ring will do the job i reckon. :)
    What do you run on the Kato ?
    PTW
    #237376
    DID or Regina 520 x ring ;)
    #237373
    Try the big gold one you wear around you’re neck boony :woohoo:
    Fully sic bling bling B)
    I would go for a good old fashioned o-ring. Are x-ring the same as a crf450x uses?
    #237391
    Hey Boony,
    If the bikes only going to do some average trailriding you could probably go a heavy duty O-Ring like an RK 520SO. But if you are doing extended miles and getting a lot of heat in the chain I’d go an XW-Ring chain like a 520EXW.
    Dave
    #237399
    O ring chain for the casual ride, Boony
    X ring for more muddy rides
    Don’t know about the difference in cost??
    craig evans
    let me know what lenght yours is on the xr and i mite have 1 you can have for just the postage, iv got a cpl diff lengths in the shed unused
