Worn out!
Home Forums General Bike Talk Worn out!
This topic contains 12 replies, has 0 voices, and was last updated by  dennis da menace 16 years, 9 months ago.
  • #96687
    Paul
    Front sprocket worn out after only 3677K’s (90% dirt riding)
    I was hoping it might last longer than that :silly:
    #141281
    Yeah,
    I got double that out of my Stoneking rear tyre:dry: :huh: ;)
    #141286
    thats normal is not it(the disadvatage of these modern 4strokes hard on tyres and chains and sprockets but the power is fun)
    #141294
    Daniel Baker
    you might as well put a 13 tooth one on it, unless you have a bigger then standard one on the back
    #141282
    If I got half of that out of a front I would be :laugh:
    #141305
    shane
    Pfffttt!
    That’s not worn out! The teeth aren’t even hooked over yet!
    #141283
    Obviously aint off a VOR then hey ShaneO:P
    #141308
    I would have thought that was pretty good going for a front sprocket. Don’t they only cost about $30.00 then again it is a BMW so it is probably 300
    #141345
    looks like it may have had side load
    how was the job of removing the swing arm? or did you only have to slide the pivot back a bit?
    #141346
    I think WIKD might have been a bit sarcastic:cheer:
    I can only fit a 12 on the Gasser and it was rooted in 1500 K’s
    #141372
    #141379
    na boony, its still got more teeth than you:laugh: :laugh: :P :P
    #141348
    Paul
    It did have a little side load – I read the book (CD rom) and it says to push the swingarm to the left side before tightening the pinch bolts, I hadn’t done that.
    Removing the swing arm is easy – remove bottom shock mount bolt (remember there is no linkages), undo nut and slide out the pin that goes through the gear shaft.
    One side bearing comes out with the pin the other stays in the frame.
    It’s all quite ingeneous really.
    Chris; genuine front 14T = $51 but I have found slightly different prices depending which dealership I go to, or should that be stealership?
