Wr 450 electrical issue
Home Forums Tech Help Tech Help Wr 450 electrical issue
This topic contains 11 replies, has 0 voices, and was last updated by  anthony 12 years, 4 months ago.
  • #103428
    anthony
    Hey OBT
    I’m having an issue with my wr 450 it’s an 04 model.
    I just bought the bike with no lights working the bloke
    Told me they work(sure) anyway now the battery won’t take
    Charge multimeter on battery terminals show it’s losing
    Volts on high rpm. I replaced rec regulator still no fix. Any ideas?
    It runs awesome until the battery drains then it pops and conks
    Out.
    Cheers glow.
    #251556
    Glow,
    Try these.
    [attachment=4228]Wrf450wiringcheck.pdf[/attachment]
    [attachment=4229]Wrf450Test1.pdf[/attachment]
    [attachment=4230]Wrf450Test2.pdf[/attachment]
    #251557
    anthony
    Thanks Adam,ill check them out,when I hit e start
    The battery drops to 5 volts also.
    #251558
    These model WR’s had a light weight starter that could burn out, don’t wind it over continuously. Just short bursts.
    If the battery is new and charged then it’s possible the starter is dying. If the battery is old then it could be a tired battery.
    #251559
    anthony
    The battery is an old one, I still gotta do those tests
    But I been trying to fault find for 2 days
    #251560
    anthony
    Btw I can’t test the .288to .4 range
    #251561
    try running a set of jumper leads from your car battery ? The regulator should be pumping out about 14 volts with a fast idle
    anthony
    Should I unplug my battery incase that’s holding it back?
    #251564
    G’day
    Have just been thru a bit of electrical issues with my WR450 albeit this thing is far from standard. :whistle:
    It ended up being the battery – you can run all the tests under the sun but if the battery is faulty it will continue to play up. :pinch:
    It should read between 13 – 14 volts at about 4-5000 rpm. If the battery is not fully charged you will never get the correct reading. Fully charge the battery and start from there otherwise get a new one which by the sound of it will probably fix it. Don’t get a lithium one get a standard one.
    Hope this helps :blink:
    Linz
    #251573
    anthony
    Thanks for help guys.. I tried off car battery but still the same.
    No lights and draining battery on higher rpm ill just take it in.
    Cheers glow
    #251587
    Cheers glow
    You may have a short somewhere ? check all of your wiring especially around the frame area where your wiring is in contact with it.
    Good luck with it
    anthony
    Hi guys thanks for trying to help. Turns out the
    Stator needs a rewind luckily I know a bloke who gonna
    Fix it once and for all.
    Cheers glow.
