wr wont start in gear
Home Forums General Bike Talk wr wont start in gear
This topic contains 31 replies, has 0 voices, and was last updated by  Matt Baker 11 years, 9 months ago.
Viewing 15 posts - 1 through 15 (of 35 total)
  • #99603
    Evan
    Me and a mate have 08 and 09 wr450 neither will start in gear,mine would when it was brand new for about 2000ks but another mate has an 06 and his will start in any gear anytime.It really sucks when your stalled on a steep hill.Does this happen to other bikes or Wrs?
    cheers Ev
    #197328
    my 06 starts in any gear to Ev.I havent had any trouble.hope you get it sorted mate.DY4
    #197331
    Evan
    Mine is also very hard to get into nuertral it is almost impossible while running and even when its off you have to rock it to get it in
    #197332
    Is the clutch disengaging properly EV. If you warm the bike up and turn it of and put it in 2nd gear can you push it? I doubt it from what you are saying.
    I would be checking the adjustment, if that’s ok I would be popping the clutch out checking the plate thickness, the steel plates arent warped and the fingers on the basket aren’t notched
    It`s stuffed ,,,Sell it!!!!!
    #197329
    Scott
    As TB said good chance its the clutch adjustment.
    I have had the same issue on mine, I was able to use the on the fly adjuster at the lever to get it sorted.
    #197334
    Evan
    At least it has a button:laugh:
    #197336
    Evan
    Tried adjuster no go How could the 09 plates be warped after 6 months but the 06 be fine?Does this happen to other makes ?
    #197335
    TheBoss
    tech help rules
    It is the only forum with a simple rule
    #197337
    Alan Heather
    ev you need a drz400 mate.:laugh: :laugh: :laugh:
    #197342
    that will fix it for sure :side:
    #197343
    Evan
    Id rather push my WR
    #197344
    Alan Heather
    That is an option:woohoo: :laugh: :laugh: ,but how hot did your bike get at bello on the hot day we were out, the other day may have warped the clutch.
    #197346
    Evan
    Mackas 06 was there that day too and it still starts Ps Al macka broke his arm that day
    #197347
    Alan Heather
    In the creek???
