This topic contains 18 replies, has 0 voices, and was last updated by Dean 15 years, 3 months ago.
November 10, 2009 at 10:25 am #97505
got a 03 wr250f it is a real bastard to start.sometimes start of the kicker . if you push it it will be ok to restart while it is hot.
it has had a recent big end repair. it runs really well when it goes . only mod is a fmf pipe.
cheers dudes
November 10, 2009 at 10:28 am #160349Does it have a hot start, does it smell of fuel? How do you start it, no throttle, full throttle?
November 10, 2009 at 10:42 am #160350well it has a hot start . red choke i hope . tired no throttle,full throttle all kinds of different kickstart techniques.choke , no choke, hotstart , i think it maybe a flooding issue, but it doesn’t really smell of fuel.got to push it 6-7 m before it will fire up.
bruceNovember 10, 2009 at 11:07 am #160353what are your valve clearances like?
sounds like a typical closing up the valves and a reshim may be due
November 10, 2009 at 11:16 am #160358Ollie wrote:
Quote:what are your valve clearances like?sounds like a typical closing up the valves and a reshim may be due
Does sound like it Ollie but it just had a bottom end rebuild he said you would hope they at least checked the clearances, would pay to check with the repairer
November 10, 2009 at 11:22 am #160360yeh mate but should take 1/2 hour to check, it is an 03 2fitty 4t.
November 10, 2009 at 11:30 am #160362sounds like valve clearance to me its cheep to check and you can check timeing chain ect is all good too
November 10, 2009 at 11:35 am #160351thank you fellers . if so many reckon it is the clearances, then i’ll get them done tomorrow.
you cant always trust the bike shops up here in townsville .as they say we are a captured audience here :cheer:November 10, 2009 at 11:42 am #160364Bruce,do yourself a favor get some feeler gauges and a manual,piece of piss to check and adjust. and you will get to know how the engine ticks.The yammy manuals are pretty good.
November 11, 2009 at 9:55 am #160352good idea ollie will do
November 11, 2009 at 10:08 am #160511It is easy to check the clearances but adjusting isn’t so easy, this unless I am mistaken requires having the correct size shims, verier calipers, removal of the camshafts, timing chain on and of timing the engine, you will need a tension wrench etc.
Checking if the clearances are out of spec is easy though
November 11, 2009 at 10:28 am #160514I am fairly certain that you will need the correct size shims and that you wont know until you measure, it is a shit easy job though, you can stretch it to a two or three can job
November 11, 2009 at 10:37 am #160515Shims you buy after you check the clearance $15 ea,vernier $25+, tension wrench $100+ or borrow your mates. Timing very easy if you can read engrish plenty of how to video’s on youtube and the satisfaction of doing it yourself: cost to have it done in a shop $250+ I guess its all about priorities
just be methodical and take plenty of pictures for backup
good luck with it mateOllie
November 11, 2009 at 10:49 am #160520Ollie wrote:
Quote:Shims you buy after you check the clearance $15 ea,vernier $25+, tension wrench $100+ or borrow your mates. Timing very easy if you can read engrish plenty of how to video’s on youtube and the satisfaction of doing it yourself: cost to have it done in a shop $250+ I guess its all about priorities
Thats better
Yes Ollie’s right very satisfying when you have done itTB
November 11, 2009 at 10:59 am #160522Trailboss wrote:
Quote:Ollie wrote:Quote:Shims you buy after you check the clearance $15 ea,vernier $25+, tension wrench $100+ or borrow your mates. Timing very easy if you can read engrish plenty of how to video’s on youtube and the satisfaction of doing it yourself: cost to have it done in a shop $250+ I guess its all about priorities
Thats better
A bit like sex really. It is OK to watch someone else do it. But is much more satisfying to do it yourself.
