XR 250 De comp seal
Home Forums Tech Help Tech Help XR 250 De comp seal
This topic contains 3 replies, has 0 voices, and was last updated by  Greg 12 years, 8 months ago.
  • #102890
    Hi All,
    I need to change the seal on the decomp shaft on my XR250, does anyone know if it can be changed from the outside or if i have to take the head off? :unsure:
    #243885
    From memory TR the tappet cover needs to come off and the shaft removed to change it
    Will confirm shortly
    I just double checked with the king of XR’s and he said it is the case as above, and you need to slide hammer out the retaining pin that hold the decompression shaft
    Cheers, thanks TB.
