Home › Forums › Rocks Motorcycles Honda Forum › Rocks Motorcycles Honda Forum › XR250, 350 top end?
This topic contains 13 replies, has 0 voices, and was last updated by Bruce Curtis 16 years, 10 months ago.
May 28, 2009 at 12:12 am #96482
A mate has a question. He has been offered a new topend off an ’84-85 XR350. He currently rides a, ’84 XR250 and is trying to find out if it will go onto his 250 bottom end???
Can some confirm or deny that the XR250 and XR350 of that era had a common bottom end?
Thanks!
May 28, 2009 at 12:14 am #136905Is that Jeorg by any chance?? If it is,it is certainly a small world.
May 28, 2009 at 12:18 am #136907I had a 84, an 86 and a 88 XR250, the 88 I had converted into a 280 and never heard of anyone doing it the 350 thing that is, I dont think it can be done, I think from Memory there are some differences between the engines, could be wrong again
So I say no :laugh:
May 28, 2009 at 12:29 am #136909Thanks TB, that’s my gut feeling too, but I have heard it said that the two engines had the same bottom end – just not said by anyone with proven knowledge!
May 28, 2009 at 12:30 am #136915
AnonymousWhat about giving ballard’s a call ECKS?
May 28, 2009 at 12:40 am #136910THe 350 and the 250 right hand crank cases are exactly the same (same part number) Although the left crank cases are different,to allow for an oil feed line on the 350. So theoretically the cylinder might just bolt on. THe gudgeon pins are different part numbers as too are the crank shaft and conrod. AS the 350 cylinder is taller I would imagine you would have to put a longer cam chain in to.
So from this I can work out that it might just bolt on,but whether you can get it to work is another matter.Info from
May 28, 2009 at 12:43 am #136916I take that back,the crank case are different,whether the bolt holes line up I couldn’t tell you from the schematic drawings.
May 28, 2009 at 12:47 am #136918
AnonymousGood work Mick!
May 28, 2009 at 12:48 am #136917micknmeld wrote:
Quote:THe 350 and the 250 right hand crank cases are exactly the same (same part number) Although the left crank cases are different,to allow for an oil feed line on the 350. So theoretically the cylinder might just bolt on. THe gudgeon pins are different part numbers as too are the crank shaft and conrod. AS the 350 cylinder is taller I would imagine you would have to put a longer cam chain in to.
What about the shorter stroke and shorter conrod :blink:
May 28, 2009 at 12:52 am #136920I mentioned that the crank and conrod are different.
May 28, 2009 at 2:46 am #136906to add to the confusion.
dose anyone know about the XL 250’s and 350’s?
my bro has a couple of project bikes as you do.
how much taller is the 350 barrel to the 250?
i forgot to mention try getting a 350 head and bottom gasket, if the bolt holes match up it should bolt on.
but as mentioned the stroke difference, comes up blank, apart from swapping the 350 conrod and cylinder into the 250. but if it dosn’t work you have to swap it all back again. so really i’m stabbing in the dark .
May 28, 2009 at 3:21 am #136928THe link I posted earlier in this thread,has all the schematics for hondas going back a fair way,maybe you could try and work it out from the diagrams and part numbers????
May 28, 2009 at 4:03 am #136929micknmeld wrote:
Quote:THe link I posted earlier in this thread,has all the schematics for hondas going back a fair way,maybe you could try and work it out from the diagrams and part numbers????:blush:
yeah i was hoping to take the lazy option= pick someone else’s brain.However thanks to your post of the Mr cycle site, i at least found out that the 85 XL and XR use the same cylinder part numbers.
AND they stock parts for the XL 70!:woohoo: !!:woohoo: !!
May 28, 2009 at 4:33 am #136931I seem to recall from the dark recesses of my mind that the XR350R was a completely different motor, a mid-sized breed that showed honda was ahead in this regard, was not an upsized 250 nor a downsized 500, I had the option a few years back on an old thumpernats CR350R and the 250 motor was not compatable with the mounts etc.
