XR600 Electrickery problem.
Home Forums Tech Help Tech Help XR600 Electrickery problem.
This topic contains 35 replies, has 0 voices, and was last updated by  Mick D 16 years, 4 months ago.
Viewing 15 posts - 16 through 30 (of 36 total)
  • #160197
    we believe it is a 1996 mod
    #160198
    So you have covered all the basics then, all the earths are good, no pinched wires, no wires hooked up incorrectly.
    The best way I have found is to start with one blinker only connected and get the front right for example working, disconnected all the others, keep things simple I keep saying, the regulator / rectifier is working cause the head light is working and I seem to think these get hot anyway, check Moose’s to be sure
    I think it sounds like its too hard Mick, you are looking for simple fix instead of the hard work of checking things would rather replace the reg and be happy :P
    I am convinced it is an earth problem.We are gunna go into it this arvo.The first thing I will do is check the earth on the coil and go from there. We will have Mooses XR there today to compare where everything is plugged into.
    #160041
    tim
    Don’t know how to attach the drawing that can be downloaded from address below, you need winzip to view the drawing, drawing title is kapite 17
    or pm me and I can email it to you
    http://motoservicemanuals.blogspot.com/2009/03/honda-xr-600r-service-manual.html
    from this drawing it really does show that it looks like an earth problem, check the horn works by connecting to a battery, your indicators and flasher acting as you described is possibly due to blown globe on the left side and lack of earth but the right side working due to it grounding through the brake light.
    your rect/reg unit should be a finned type unit and is made such due to the heat it produces so should be ok, the spare you talk about having CDI written on it is not the same rect/reg, different gezmo!
    as far as the engine stopping check the engine stop switch is not dodgy
    hope this helps some way, please don’t kill me if it does not! :P
    #160230
    It isn’t the one with the fins on it under the seat that gets hot it is the one behind the headlight.
    #160233
    Isnt that the flasher can?
    tim
    hopefully that is the flasher you are talking about otherwise I did find that there is another model with a AC regulator that is mounted behind the headlight i will send you that drawing also, the problem is I have only found drawings of overseas models the U AND B I assumed the U would be the same as the Australian model
    #160243
    Thanks medogrocket,
    The diagram is just what I need. Yes there is another dodad behind the headlight that has a sticker on it that says regulator/rectifier CDI unit. It also has a barrel shaped do hicky with two wires going to it,straped to it with a rubber band thingy. It is a totally different unit to the AC regulator that has fins and is found under the seat.
    #160245
    tim
    Just thought, as a quick test, use the earth from the horn and earth to a metal part of the frame as good as you can, see what that does, gives you an easy 2nd earth
    #160266
    You have spent the whole day scratching your chin over this haven’t you Tim? Your efforts are appreciated and some good karma will come your way in some form or another in the future.
    Mick
    #160042
    tim
    electrical problems sh*t me, I always liked the old XR’s and hated it when Honda went to the CRF’s, that’s why I no longer have a Honda, always like trying to fix things like this if I can find the patience and time, but hard if you are not with the bike, let me know what you find, it will be some stupid little thing I bet.
    #160281
    Got a multi meter and will get it sorted by an expert tomorrow.I’m over it. We have an auto sparky mate coming tomorrow arvo.He’ll work for beer I am hoping. :laugh:
    #160302
    Very Pea hearted approach Mick and you are a mechanic by trade :blush: .
    Surely with all the practical help you have got here the last two days and a little effort and time you can fix it yourself, will ring you
    Pea hearted??? Mate,Tripper says he is gunna pay someone to sort it out and I am stoked that I dont have to do it!!
    Yes a mechanic by trade a plant mechanic to be exact,quite different to an auto sparky. Want tracks on your dozer? Fine! Lights dont work? Call a sparky. :laugh:
    #160373
    Make sure you post up what the problem is Mick when you figure it out. There are a few XR’s floating around here so will be good for future reference.
