XR650R TM40 pumper jetting spec’s
Home Forums Tech Help Tech Help XR650R TM40 pumper jetting spec’s
This topic contains 17 replies, has 0 voices, and was last updated by  geordie 12 years, 9 months ago.
  • #102249
    geordie
    G’day, i have a tm 40 pumper fitted and in tight tracks the bike is running hot 96>110 most of the time i have hit 119
    i have unibike rad guards which i’m sure hinder the cooling, it also has a jp 11:1 piston i never had the trailtec vapor on when i was stock so have know idea what it use to run it in the same terrain then :dry:
    i think there is room to improve in the jetting currently run 32.5 pilot 1.1 air jet starts well/easy stock needle on 3rd clip down y4 needle jet and 142.5 main,
    i have the pump jet set nice and early as it was pinging badly on nasty hills when going slowly
    any help / input would be great
    cheers
    #235065
    Nick Dole
    95-100 is where you want to be.
    I did a TM40 a few weeks before Christmas, 32.5 sounds right, as does 3rd clip on the stock needle and the Y4 needle jet.
    If it’s rattling on bad hills when the temp gets up it’s a band aid to use fuel to cool the combustion. If you tend to get stuck on hills run an electric thermo fan. I prefer the fan automatically cuts in at 105 ish.
    Having said that it sounds like you are borderline on cooling with the radiator guards. Radiators need airflow and if you are both riding slowly and have obstructed the airflow you need to change something.
    Bigger radiators will help by sheer volume of water and the 650R runs a thermostat so you can’t over cool it. Added bonus is most brands of radiator are far more durable then the stock ones, you may not need the braces.
    #235082
    geordie
    thanks for the reply nick i thought that range was where it should be,
    if you don’t mind can i ask if not from lean fuel what does it rattle/ping?
    i have thought about a fan some say get a little 12v computer fan others reckon ktm set up is the go but i am clueless with elec system, what is the best option for this as it would be a great to have?
    i am using engine ice and that has lowered the running temp the uni biker guards do hamper the air flow but are great protection for the area’s i ride mostly tight single and hills i do tend to collect sticks and rocks in rads and drop it sometime on hills i have the upgrade thermostat from xr’s only and cap
    am am thinking of the cheap ebay rad’s from ASI
    http://www.ebay.com.au/itm/performance-aluminum-radiator-Honda-XR650R-XR650-00-07-/300717546478?pt=AU_Motorcycle_Parts_Accessories&hash=item4604299bee
    i would buy fluidynes but for the cost
    cheers
    #235092
    Cheap ones are crap they crack around the tanks. I have a set of PWRs and they are awesome, well made. PS I dont know why Glen had trouble getting his to fit :whistle:
    Well made, strong and Aussie. Oh yeah much more expensive then the Chinese ones you should compare the quality :huh:
    Just my opinion
    geordie
    Just my opinion
    yes i have had a couple of people say to steer clear of the ebay jobs i do like the pwr’s but man there prices :sick: over $600
    i wondered about glen’s fitting issue?
    i am thinking fluidynes at $400 landed if pwr where closer on price i would buy there’s
    #235102
    Yeah the Fluidynes are a lot better than the ebay Chinese ones
    Nick Dole
    I’ve only had one experience with the Chinese radiators, on a CRF250R. A kid I help out needed a radiator in a hurry as his was banana shaped and leaking. PWR could not supply fast so we went for the $110 a set delivered option.
    50 hours later they are still on the bike and he won the lites class in amcross with them. Crash tested them a fair bit too, they held up well with no braces.
    Made the bike run at 60 degrees though, had to tape a whole radiator up to get to 95
    #235093
    quote]
    Hey Nick I would also be interested in knowing what the G O is with fitting a thermo fan as you know I mainly use my BRP to commute to the city and on some days the temp gets up quite high and find myself doing silly things to keep the airflow going through the rads :laugh:
    I fitted a computer fan and small 12v battery with a total loss system but its just not good enough for city traffic.
    Nick Dole
    “hi nick, thanks for your reply in my thread can i ask you a couple of questions?
    if the pinging/rattle isn’t from fuel what causes it? what can i do to fix this problem? i never heard it with the stock piston and carb so assumed it had to do with running lean from pumper and hi-comp je piston
    can you point me to good info on fitting a fan? i think i have found a 2nd ktm 640 adv setup,
    i am looking into fluidyne radiators the pwr’s look awesome but my budget doesn’t
    any advice or info is greatly appreciated i love my brp and would like to have it issue free.”
    Detonation can be caused by lots of things. In short it’s the early spontaneous combustion of the fuel/air mix. Now it can be caused by too much ignition advance and other tuning related issues like hot spots in the cylinder head and combustion chamber designs that are prone to pre ignition but your engine is pretty stock so lets stick to what’s making yours ping/rattle/detonate.
    If it runs fine at 95-100 degrees and only starts rattling at elevated temperature id suggest there are a few things going on.
    1. The piston you now have is a flat top i’m assuming. the stock piston is dished. The dished piston for the same given compression ratio is better able to control the burn ( it’s actually a chemical reaction but lets not split hairs here) then the flat top. My experience is if i can run a slightly dished piston over a flat top, even if i lose a point or two of compression, i will have a better end result in terms of power and resistance to detonation. the flat top does little to centralize the combustion and usually the valve pockets are quite sharp that can become heat risers if we are running on the edge of detonation. These heat risers or hot sports act like glow plugs in a diesel and cause combustion to occur before the plug fires.
    I can’t emphasize enough how damaging detonation is. The piston and rod are having to compress the ignited mixture, placing massive stresses on the rod/piston/crank. This actually compounds the hot spot problem so the problem gets worse.
    It’s for this reason i don’t use a flat top if i can avoid it, in the safari engines where i knew we would get awful fuel we still ran 10.8:1 but did it with barrel machining and running a 1.0mm squish band to cool the outside of the piston.
    2. Heat. If it’s OK at 95-100 why not just keep it there? most road bikes use thermo fans. A quick look on ebay will get you a little fan that is more waterproof than a fan computer. The KTM one will be fine. You will need a switch in the cooling system to turn it on, i’d tap a hole in the coolant elbow that runs out of the XR650 Head, that way of you stuff it there are no tears before bedtime on a replacement. You can always have a little boss welded onto it for added thread depth.
    Below is a crap wiring diagram that will get you going. note i switch on the negative as it’s safer for shorts (fan just turns on, no melted wires) For power, the XR650 Runs the headlight and tail light on AC and the blinkers and horn on DC ( all XR’s do) as the rectification losses are too much for the pissant 70watt stator. So take power from the horn circuit, chances are it’s not being used anyway.
    __________
    #235174
    Nick Dole
    geordie
    thanks for the great reply i have a je 11:1 raised top piston, freshly overhauled head with kibblewhite valves and spring std size, just running stock stator and ign pick up long story to this bike but you have atleast built the rear shock it was previously owned by a bloke know as “advjake” he live in sydney at the time was sold to a tourist and then stolen and recovered in cairns
    in full stock form oem piston etc jake fitted a tm40 pumper and had the same denoting problems and reinstalled the stock carb and it run well this is how i got it
    a mate and myself rebuilt the motor, the head was done at a local shop i supplied the hardware i did run it with stock carb for a short time at run in then decided to install the tm40 the denoting only happens under heavy load i am 150kg+ and it normally happens on hills starts, laboring the motor on a hill never use to do this with stock carb , it happens below 95 but is worse when hotter,
    i am running 15/48 gearing and use engine ice coolant may not mean sfa but thought i’d add incase
    Thanks for the advice on the fan i will use it in sorting out a fan, I am also considering bigger rads fluindybes mostlikely the pwr’s are out of my budget
    #235067
    geordie
    [img]http://i35.tinypic.com/k4tfk0.jpghttp://[/img][img]i35.tinypic.com/k4tfk0.jpghttp://[/img]
    not my motor but piston looked the same as this 1
    #235177
    Nick Dole
    From that it could be a bit lean, have you tried going bigger on the main?
    I’m no TM40 expert but i did find them very course in jetting changes, what would be a small change on an FCR was a leap on the TM40.
    I’ll try and find the jetting i used on the last few i have done, didn’t have any detonation issues.
    #235178
    11:1 compression is high! No room for error there. Sounds like its running lean under extreme load. Bigger main jet might help. Apparently a bigger main jet would have helped reduce the chance of my 450 doing its big end bearing as it also used to ping under load.
    #235068
    geordie
    it only denotes at low speed on start of throttle which is why i went to a 32.5 pilot it helped with denoting so i then went to a 1.0 air jet but that was too much and wouldn’t start nicely etc i have the pumper set very active as soon as the slide starts to raise the squirter kicks in i was at 145 main with a y6 needle jet and it was running a black sutty pipe so dropped back to a 142.5 main and y4 needle jet, i thought it is strang jake had problems as i think he is normal size and engine was in stock form at that stage
    i may have to source a decent stock carb
