XR650R Valve adjustment D.I.Y
This topic contains 4 replies, has 0 voices, and was last updated by  Greg 14 years, 10 months ago.
  • #99870
    So after a “gidday mate” opening to a phone call from the Mayor I thought umm whats doing here it turned out to be a how do I do a valve adjustment on my piggy again phone call and then the next 3 calls back and forth while I explained valves closing and opening and rocking etc and he juggled the phone, I thought we need a DIY and I should have done it before really. Its never easy for the people on either end of the phone try to explain what they see and what your remember.
    I aren’t going out to take photos this time of night so I borrowed this one
    Red arrow Timing plug
    Green arrow exhaust valves
    Blue arrow Inlet valves
    Valve clearance for a stock XR650R should be:
    IN:0.15 +- .02mm (0.006 +- .001 inch)
    EX:0.20 +- .02mm (0.008 +- .001inch)
    Although I run my slightly different
    Step by step
    1. Remove the seat and petrol tank.
    2. Clean around the tappet covers, spark plug and flywheel housing timing plug the top one in the flywheel housing (red arrow)
    3. Remove the tappet covers
    4. Remove the spark plug
    5. Remove Timing plug.
    6. Rotate the flywheel counter clockwise two or three revolutions using the back wheel to turn it, remember 5th gear not 1st gear Mick.
    7. Watch the valves, exhaust valves down and then as they come back up the inlets will start to go down as the exhaust finish going up. That is the valves rocking, it is also the signal you are getting close as your piston is coming back up on the compression stroke. To make compression all the valves need to be closed and that’s when we do the adjustment because unless its been dusted or the likes all the valves should have clearance (you should be able to wiggle the rocker arms)
    8. Line the “T” up with the “notch” on top of the flywheel housing plug you removed. If the “T”goes past the notch, start over. You don’t want to activate the decompression mechanism. Make sure you are at top dead centre (TDC) on the
    compression stroke. A simple way to check this is by moving the rocker arms up and down once you’ve aligned the “T”. This can be confusing if the inlets are closed and you can’t get that movement. If you have followed the above it will be right so you can adjust then inlets. Don’t worry at worst you will end up with loose noisy valves and have to do them again is all
    9. Using a feeler gauge check the clearances on the intake valves (closest to carburettor) they should be 0.006 Exhaust valves closest to where the exhaust system comes out of the head should be 0.008
    10. Adjustment them using a 10mm spanner and a small screw driver, use a ring spanner and don’t over tighten the lock nuts because you will stretch the threads. Make sure the feeler gauge has a slight drag while pulling it out and sliding it
    back in. Be sure to keep the screwdriver steady with no turning while you re-tighten the lock nut.
    11. Re-assemble everything and fire her up. With the valves properly adjusted it will start easier hot and cold especially cold.
    Thanks TB, I went into it without taking a great deal of notice before hand. I presumed it would be much like doing the XR600 valves (which I have done a heap of times). Although they are a bit the same, there where a few differences. ie. You can spin the crank on a 600 with a 19mm socket to find the timing marks, where as the 650 can’t be done that way and you have to spin the wheel to find the marks.
    #200728
    ‘Bout time I gave it a go.
    Thanks TB
    #200741
    It has made a world of difference to my BRP. It starts easily, will idle when cold and she has loads of compression. :woohoo:
    #200746
    I said that yesterday and you it was starting ok as it was :laugh: like I said it will be better. You fitted a new plug as well didn’t you? Amazing how much compression they have, cant wait till mines rebuilt :woohoo: Crash has said before a new plug and a valve adjustment and happy days, smart man the out going King
    All hail the KING :P :silly:
    Good job Mick ;)
