yamaha counter shaft seal.
Home Forums Tech Help Tech Help yamaha counter shaft seal.
This topic contains 5 replies, has 0 voices, and was last updated by  Greg 14 years, 2 months ago.
  • #100844
    I have a wr 450.Im in the process of changing the counter shaft seal.
    Just wondering if there is a flat Oring behind the seal.
    Seal is out.No probs.
    Will get the collar of tomorrow when i get more tools.Is this an Oring i can see behind the
    collar.
    Cheers …Spud…
    #213385
    Spud,
    Try this link to Thumpertalk.
    http://shop.thumpertalk.com/oem.asp?partcategory=554760&manufacturer=6&category=3&year=2007&model=12882
    This was for an 07 but you can search for others if not the same.
    Looks like an ‘O’ ring behind the bearing ;)
    #213386
    jamie
    This link has a good schematic and parts list,with the o ring.
    http://www.bikebandit.com/houseofmotorcycles/2007-yamaha-wr450f-wr450fw/o/m18998#sch644854
    #213388
    Thank you Adam and Twobanger.
    that is the diagram i was after.My manual dose not have that.
    I hope mine is the same.As it is an 06 model with the old steel frame and motor.
    Thanks again…spud…
    #213389
    Man I was to slow, in the time it took me to research it Adam and 2 banger were all over it I see ;) Good work guys
    Here is what I found Spud, better late then never :laugh:
    (Hey Spud,the picture below shows the O ring number 27
    Here is a piece I found on the net http://www.thumpertalk.com/forum/archive/index.php/t-703925.html hope that helps mate)
    jamie
    :laugh: your right TB,1 min between the first 2 reply’s,gotta love the net for gettin info fast.
