Yep DR 650 rear shock question :-)
This topic contains 8 replies, has 0 voices, and was last updated by  Chris 12 years, 1 month ago.
  • #103476
    My DR currently has a MPE set up in it from the PO and he tells me its set up for a light weight fella 110kgs
    Im slightly bigger ;) lets round it and say 130kgs :S
    What rear spring would you recommend for me, thinking that I will be doing a big ride in 2015 so will have a good load on the back as well
    I have no idea what has been done to the front but im guess it should be ok for now
    My DRZ 400e also has MPE from the PO but has a Teknik 6.6 rear spring are you able to confirm what this is rated to for me :-)
    Many Many Thanks
    Shaker aka Chris
    #252154
    Nick Dole
    Hi, late reply…sorry…
    6.6 is about stock, you sure thats right? Our general rule is 8.0 for under 90kg. 9.0 for 95-120kg and 10.0 for 120kg plus.
    That’s rider weight only, it accounts for 20-30kg subframe snapping gear.
    #252293
    thas ok I f i really was in a hurry i could of picked up the phone lol
    I just rechecked and it is a 6.6 spring so I guess I best repalce that one as well or my fat ass will break it hehe
    So my next question would be, how much for a 10.0 spring for a DR and DRZ :-)
    How hard are they to remove….I have done springs in a car before with a mate and i havent died from doing that yet.
    Im not sure how long ago the suspension was done so my guess is it may be better to send the hole shock assembly down to get it looked at…..gezz how much would that be.
    thanks in advance
    Shaker
    #252294
    Nick Dole
    Shaker,
    You won’t break the 6.6, just squash it when you sit on it. ;) If the 6.6 is in the 400, that’s more like it, still a bit light for you but not too bad. 7.2 would be better. see how it feels.
    If you are REALLY 130kg id use the 10kg in the 650. It’s a fkn big spring for the DR and I really only use it for the biggest heffalumps. Either spring is arrr $150 OB price.
    Hard to know what’s in the shock, BUT i do run the rebound dampening WAY harder for these big springs to prevent PDS (pilot discharge system) type crashes when the stored energy in the spring tried to launch you into sub orbit.
    Shock rebuild/revalve $220 plus seal/bumpstop/parts if required. DR650’s are pretty good, nothing much goes wrong.
    #252295
    Thanks for that…
    I will call on Monday and sort out a large ass rear spring for the DR
    Also when I removed the spring I found this
    Not sure what the 9.0 is but ill call MPE on monday and see if they can shed some light.
    Question will the DR spring fit the DRZ ?
    This is me….yes im holding it in
    #252302
    Nick Dole
    That’s one of my 9.0kg springs. It will be OK for you, just a little light.
    The 650 and 400 shock is totally different, can’t swap
    #252303
    Ok thanks for that….looks like I have to put the bloody thing back together lmao
    MPE must use ur springs ;)
    #252304
    Sorry i missed this part..more over the springs not the whole shock ?
    #252155
    Just got off the phone with Nick…new 7.? spring on the way for the DRZ400e
    Might stop the bike from swollowing the rear tyre till it hits the rear fender…well almost on those jumps that my body says im not to do lol
    Can not wait to check it out
